I"m working in this set that not power on and is not Vs or Va present,replaced power supply and still the same any ideas guys.
LG Plasma 42PJ350-ub wont power on
Tags: None
Re: LG Plasma 42PJ350-ub wont power on
Unplug Y-sus and Z-sus, then see if it powers up.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
OK, by no power, what do you mean? Does the power LED come on? Do the relays click? Do you have voltages Vs and Va?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
On the control board, do you see two points marked EXT AUTO GEN?
How about some pictures of the boards? I don't have this TV in front of me.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
PROBLEM FIXED.
I replace the power supply and still not turn on,after i order A board instaled and tv back to live.Comment
But LG don't use "A" boards.... Do you mean the main board?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by CooperrI picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... - Loading...
