Goodmans LD3265D2
    Re: Goodmans LD3265D2
    That is normal for that lead to be missing on that diode. It's part of the manufacturing process.
    • newtothis
      • Mar 2013
      • 1556
      • england
      Yeah I noticed that once I got the new one.
      Will attempt a repair on the old board one of the days.
      • newtothis
        • Mar 2013
        • 1556
        • england
        Ok so the tv was good for a while... Then came back the fault... It has gotten worse of time reoccurring more often to the point now that the blasted thing won't turn on....
        Now... If I leave it unplugged for say a week it will work first time then slowly get worse again.
        Any ideas?
        I can use a multimeter to basic level... Check polarity, check voltage, ohms, capacitance. I have ordered an ESR meter which I should have in the next 14 days so I can properly check the caps.
        How do I go about testing diodes etc and how exactly would I go about fault finding?
        • Clydeuk
          • Jan 2012
          • 193
          Is it a new or salvage power supply you've fitted? The PW26 I've found is one of the more robust Vestel supplies, but they are suffering with poor quality components etc. I know the PW25 was a horror for self destructing, seemed the UF5401 diodes shorted, I believe there was probably something out of spec on the primary that led to the failure. The PW26 is a better supply but evidently yours isnt happy somehow
          • newtothis
            • Mar 2013
            • 1556
            • england
            It was a salvage, worked fine to start with though then progressively worsened
            • Clydeuk
              • Jan 2012
              • 193
              #26
              Dare I suggest bad caps lol
              • newtothis
                • Mar 2013
                • 1556
                • england
                #27
                There are no bulges and all caps read out ok on the multimeter... But until I test their ESR values I won't know. I know that d881 diode is a common fail, it's a BYV27-200... Data sheet here :
                On diode setting on my meter it reads .467 , it is closed in reverse reading giving infinity... Is this diode good or bad?
                  That's a good diode.
                  • newtothis
                    • Mar 2013
                    • 1556
                    • england
                    #29
                    Thanks Tom
                    Ok I will wait til I have my ESR meter then go through the circuit one thing at a time testing them.
                    • newtothis
                      • Mar 2013
                      • 1556
                      • england
                      #30
                      Tom I noticed on another thread you told someone how to test the three legged components attached to the heatsinks... Whatever these are called... Can you just let me know what they should read under testing?
                        They are diodes, or MOSFETs, maybe. How about a picture?
                        • newtothis
                          • Mar 2013
                          • 1556
                          • england
                          #32
                          Pointing the screwdriver at the sucker
                            What is part # on it then?
                            • newtothis
                              • Mar 2013
                              • 1556
                              • england
                              #34
                              Sorry for the late reply,
                              I did a bit more reading and managed to test the other diodes and mosfets using my DMM. They turned out fine. After testing the outputs from the psu I noted that the 24v was only pushing 16v... So I tracked back through the circuit and found three parallel smt resistors that were knackered... They read 3k instead of 300k, they are R817 R818 and R819 on the circuit side of the PSU. Replaced all three and set now works fine.
                              Thanks for your help
                                Nice one. Which side -- primary mains side or secondary output side -- were they on?
                                • newtothis
                                  • Mar 2013
                                  • 1556
                                  • england
                                  #36
                                  Secondary side Tom.
                                  I'll put some pics up soon with info so if anyone else encounters the same issue they can take a look.
                                  Well considering I knew nothing at all about electronics 4 months ago I don't think I've done too bad.
                                  • newtothis
                                    • Mar 2013
                                    • 1556
                                    • england
                                    #37
                                    for some reason i cannot edit my above post.
                                    corrections - The SMD resistors are supposed to have read 612k.
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      #38
                                      It is kind of odd for a resistor to read lower. They generally fail open or higher than their rating. Nevertheless, good job on the repair.
                                      PS. I found a few blown SMD resistors on the cheap $5 multimeters.
                                      --- begin sig file ---
                                      --- end sig file ---
                                      • Egidio85
                                        Samsung NP750QFG-KA3DE does not turn on , Blue LED flashes 3 times
                                        by Egidio85
                                        Hi everyone, I have a Samsung NP750QFG-KA3DE , MainBoard VESTA3-15 BA92-24515A
                                        the battery is charged. pressing the power button the blue LED flashes 3 times and then stays blue. then the sequence repeats.
                                        the fan does not start.
                                        I noticed that I have no power on the processor and it does not heat up. could it depend on the bios?​
                                        any advice on what to check?
                                        06-10-2025, 05:00 AM
                                      • cajoeg
                                        Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                        by cajoeg
                                        Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                        The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                        02-10-2025, 04:01 PM
                                        Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
                                        This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                        09-07-2024, 05:50 AM
                                        Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                        09-07-2024, 05:00 AM
                                        Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook 300 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
