samsung LA32C530 LCD TV not powering up (relay clicking)
    Re: samsung LA32C530 LCD TV not powering up (relay clicking)
    What do you have on the BL_ON (INV_ON)? It should also have >3V on that pin of the power supply board. Did you also cut the BL_ON wire?
    • jork
      • Feb 2013
      • 15
      • India
      yeah I did cut the BLU_ON also. It is showing 3.3V on PSU side and some .8 on MB side. The PS_ON on the main board side is varying from 3.3 to .2. Now I understand this was the frequency the other line voltages used to vary when I connect PS_ON to board. Why do you think the backlight is still not working? should it have something to do with the LAMP_DETECT. the line is showing something ~1.8V steady.
        There may also be a backlight dimming pin like BL DIM.
          Post 10 "PWM_DIMMING : 0.1 - 1.5 varries"
          Do you still have this signal, it is an AC signal at about 150~200 Hz.
          • jork
            • Feb 2013
            • 15
            • India
            sorry for the delayed response. I had some broadband issue over the weekend.
            I just checked the PWM_DIMMING once again. the Pin shows about .8V now, constant.
            Do you think its a Main board problem still? I can try changing the main board, but just thought of making sure before spending money on that.
            Also, just to state the original problem. It all begin with a double image on the screen (one regular image and a less bright shadow sort of image below) and when I disconnect one side of T-Con the active side was perfect. If I connect other side alone, it still had the problem (this made me think its T-CON problem on one side). The support guy said the whole panel has to be replaced withought much diag. If its really a panel problem, it may not worth spending on the main board now. If I can get rid of the problem by replacing T-CON, I can think of replacing the Mainboard now (I already bought a T-CON board for around $50)
            Again, thanks for your help and support.
              At this point, you do have main board problem, we are just trying to find out if you also have the power supply board problem or not. If you disconnect the cable and the main board and can see that the backlights do come on, that will verify that the backlihgts circuits are OK.
              • jork
                • Feb 2013
                • 15
                • India
                #27
                sure. And what do you think about the original problem. do you think it could be just T-CON problem or might as well be a panel problem as the service guy said?
                  09-07-2024, 05:50 AM
                • Journey11
                  Samsung TV won't turn on ... keeps cycling the power relay on & off
                  by Journey11
                  Hi All,
                  First time posting here ... my name is Kevin but my friends call me Journey.
                  I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                  After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                  It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                  07-04-2024, 02:44 PM
                  09-06-2024, 11:40 PM
                  09-06-2024, 08:40 PM
