Samsung LN-T4061F power issue
  • ryan74
    • Oct 2012
    • 471
    • usa
    This Samsung lcd has power issue. It doesnt always turn on and when it did I got lines on screen like in pic1.
    I opened it up and saw 4 visible bad caps that are Samwha WB 10v 1000uf in pic2.
    I plan on replaceing all 7 caps in pic 2 with panasonic FM or FR unless someone thinks I should replace more or use something else. These 7 seem to have a high failure rate.
    Ebay kit is $12 otherwise it cost me about $10 for panasonic FM/FR from digikey.
    Will a 16v 1000uf panasonic cap be fine? Or is that too high voltage rating?
    Re: Samsung LN-T4061F power issue
    Nice easy fix. I would use Panasonic from Digikey. No telling what crap eBay sellers may dish out.
    Voltage rating is a higher or same spec.
    • ryan74
      • Oct 2012
      • 471
      • usa
      I agree. I have used a few kits before and sometimes the dimensions of the caps they send arent the same. I had to leave 1 cap almost a half inch off board crammed inbetween other caps.
      original-Samwha WB 10v 1000uf
      I have 2 16v 1000uf panasonic I thought of useing but since I have to order I will look for 10v 1000uf.
      • cashkennedy
        • Aug 2011
        • 668
        You can always increase the voltage on caps, you should generally increase the voltage whenever you order new caps, because that is the maximum voltage before they pop, and cheap board makers in china often pick ones that are way under what they should be.
        Those 10v caps might be filtering a 12v line, so they are always going to be over their max safe range (up to 10v), if you replace them with 16v caps they will generally be within the safe range (anything under 16v)
        The capacitance you dont want to alter significantly (more then 5% ?) unless you are very knowledgeable on electronics and know how the capacitor is being used. But the voltage rating is always safe to increase.
        I think FM, FC are the caps you want to use in the secondary of a power supply, the FR arent bad, but arent usually recomended for that purpose, i wouldnt sweat it if you already used / or already have some FR's though since theyre a good quality cap.
        Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
          One thing I would say is the one thing Samsung did not do is over-volt the caps. The 10V caps filter the 5.2V line and 16/25V caps filter the 13V line.
          • ryan74
            • Oct 2012
            • 471
            • usa
            This post covers some concern I had about a couple of the caps being slightly different.
            Warning- pics posted inline
            https://www.badcaps.net/forum/showthread.php?t=12922
            • cashkennedy
              • Aug 2011
              • 668
              Way to use double negatives, now your really going to confuse him :p
              10v caps for 5v rails , and 25v caps for 12v rails seems pretty decent to me, if you go much larger you can run into size issues. Id still replace all the 10v ones with 16v caps, and replace all the 16v / 25v ones with 25v ones.
              Are you fixing the same board like 2 years later??? Unless your running a bar / gym with multiple units with the same model, then you have some slow turn around rate
              Edit : That post isnt by you, i feel like an idiot now.. lol
              • ryan74
                • Oct 2012
                • 471
                • usa
                I picked parts I think will be good replacements.
                For the 10v 1000uf I chose.
                http://www.digikey.com/product-detai...1CT-ND/3072211
                for the 25v 220uf.
                http://www.digikey.com/product-detai...2411-ND/613772
                for the 25v 1000uf. (This one is 10mm dia.)
                http://www.digikey.com/product-detai...9CT-ND/3072229
                for the other 25v 1000uf(12.5 dia.)
                2 10mm(above) should be fine but if you want...
                http://www.digikey.com/scripts/dksea...508=55&stock=1
                Iam just a hobbyist... No guarantee my choices are the best choice.
                  Those look fine to me. I almost always use Panasonic caps as replacements. If they aren't available, I use, in order of preference, Rubycon, Nichicon and United Chemicon.
                  • mrbudders
                    • Oct 2013
                    • usa
                    Just wondering if you got the set working. I have same set with same issue. Thanx ahead.
                      09-07-2024, 05:50 AM
                    • vincentedel
                      Samsung SyncMaster 740n Phase Control Issue
                      by vincentedel
                      I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                      I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                      04-22-2025, 12:33 AM
                    • Manucsl
                      QE65Q800TATXXC Samsung TV Issue
                      by Manucsl
                      Hello.
                      My TV is a QE65Q800TATXXC Samsung TV.
                      Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                      Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                      Any ideas to check would be very appreciated 😊
                      After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                      02-19-2025, 07:47 AM
                    • FourRunner
                      Display issue Samsung TV UA65JS9000W
                      by FourRunner
                      I purchased a used Samsung TV model UA65JS9000W recently knowing it had an issue with the screen. When switched on the picture was bright both sides of the screen but a little darker in the middle of the screen. Thinking this was the back lights (side mounted LCD strips) I replaced these, however the issue is still there. I am now thinking it may be a TCOM issue, but am not sure, any advice on this would be appreciated. Also whilst changing out the back lights I noticed the the thick clear plastic sheet (maybe 1.5 to 2mm thick) below the diffusers there is cracking (up to 75mm) on the sides and...
                      10-03-2024, 07:05 PM
                    • ScHAmPi
                      Samsung UE48JU7000 screen issue after backlight replacement
                      by ScHAmPi
                      Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
                      I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
                      07-15-2024, 05:41 AM
