Vestel 16PW810S PSU
  • nogger
    • Aug 2010
    • 190
    Vestel 16PW810S PSU
    Got a PVR in with the Vestel 16PW810S PSU installed, can't seem to find a drawing anywhere. Just need to check the outputs are correct so wondered if anyone had one ?
    Cheers
    Graham
    Re: Vestel 16PW810S PSU
    Spotted this on digital spy. A friend with firmware issue, good PSU:
    1- 0.64v
    2- 3.30v
    3- 3.30v
    4- 5.5v
    5- 0.00v
    6- 0.00v
    7- 11.88v
    • nogger
      • Aug 2010
      • 190
      Thanks Tom, those are pretty close to what i have but the 12v & 5 v are down a touch (off load).
      The complaint was the box was dead, i have changed the usual secondary side caps (in fact most of the caps) & i assume that the 5v & 12v on that connector eventually feed the disk drive. That being the case then there must be a feedback issue because hooking a drive to those points kills the 12 & 5 volts (as usual i dont have the complete kit, just the PSU). There's also a second connector on this board that feeds the front panel so any info on it's pinout would be useful. Will post a pic tomorrow as the natural light is bad here now.
      Regards
      Graham
        Possibly a bad startup cap.
        • France_53
          Vestel tv, how to flip the image?
          by France_53
          Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
          05-12-2024, 05:22 AM
        • FlailingEngineer
          Help with Bush Tv (Vestel 17mb95m Mainboard)
          by FlailingEngineer
          Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
          Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
          05-31-2023, 06:52 AM
        • massimomax
          Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
          by massimomax
          Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
          spero che qualcuno può averlo per riprogrammare eprom. grazie
          Post in English !!!
          I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
          02-28-2025, 07:27 AM
        • Adenitz
          Troubleshooting Vestel TV, has standby, but cannot turn ON
          by Adenitz
          I need advice in troubleshooting Telefunken TV (it is actually Vestel). There is red Standby light but TV cannot be turned on either by remote control (which is good and tested on another TV) or by actual on/off switch at the back of the TV.
          Power board is Vestel 17IPS71 and I'm not sure about the mainboard, it seems like 17MB82S
          Both boards are shown in the attached photos.
          What is normally first that is checked in this case. I have removed power board, make sure it has no dangerous voltage on the big caps and check many components (transistors and diodes)...
          12-27-2023, 03:43 AM
        • Karlito19
          Vestel 17MB185 Toshiba 50qa5d63db
          by Karlito19
          Hi I am looking for a firmware dump for this vestel board, please
          12-16-2024, 03:29 PM
