Just a little help please TH-42px60 missing 14v power supply
  • davewilson61
    • 110
    • usa
    hey guys
    ran through the service manual and got my tv problem down to missing 14v on p board...what i have done is the service link below
    tv blinks 10 times before the power button is pushed
    copy and paste....."Panasonic_TH-37PX60_TH-42PX60_TH-50PX60_...2PD60U42_Troubleshooting_Charts_[TM].pdf".......to look at
    thanks tom66 for the service manual from a different post
    it says remove p10 from p board and check the v at pin 1 should be 14v for only 3-4 seconds till relay clicks off
    i get 0v to start with probe on pin 1 plug in tv it jumps to .34 then 3-4 relay clicks and back to 0v
    any help on the missing 14v
    like to fix just one plasma tv in my lifetime ...lol they are hard
    thanks dave
    Re: Just a little help please TH-42px60 missing 14v power supply
    Just an ordinary power supply failure here. Nothing more tricky than an LCD. Check the PSU output diodes, and any attached loads for shorts.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      03-31-2024, 02:12 PM
      07-01-2024, 06:34 AM
    • CMCM
      Russound CA4 Power Supply Repair
      by CMCM
      Hello Everybody,
      Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
      Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
      The outputs marked 12v and 20v are all measuring only 1v.
      The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
      The capacitors physically look clean (no bludgesor leaks) and...
      07-03-2025, 01:12 PM
    • JimBanville
      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
      by JimBanville
      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
      09-13-2023, 07:21 AM
