Samsung LE32B450 display problem
+ More Options
Posts
  • artois7
    • Mar 2011
    • 159
    Just purchased this TV. The display is very distorted with 2/3 vertical strips running down the tv. The blacks all appear yellow, and when you leave the TV running, the whole screen turns into a yellow wavey madness.
    I've taken a few pictures which I hope show up the problem, but the cameras died now so I couldn't take as many pictures as I wanted to!
    I took the back off and unplugged the mainboard, which resulted in just the backlight and a black screen, so from this I think? the panel is OK. Same result by unplugging (what I believe to be) the T-con.
    There's a very loud buzzing coming from the power supply, which stops if you unplug the mainboard.
    Sound works fine.
    I'm thinking it's either the T-con or the mainboard. The T-con is available used on ebay for as little as £5, but the mainboards are more £30-£35 or so.
    Can anyone point out where the T-con is?
    I hope the images are OK. I haven't got my proper camera right now, so I'm using an old one. Picture 6 is what happens everytime you switch channel.
  • drpj23
    • May 2012
    • 528
    Re: Samsung LE32B450 display problem
    It looks like your TCON is integrated into your panel.
    But, judging by your last pic, the text seems unaffected by the distortion which can lead to be the main. And it seems your OSD is affected but only the background of the text (ie text box/menu) but the text itself seems fine.
    Btw, disconnecting the main to test panel functionality is a poor test since doing that practically means the panel is "OFF".
    • artois7
      • Mar 2011
      • 159
      I don't think it is integrated;
      http://www.ebay.co.uk/itm/Samsung-32...item2327c88689
      The text is unaffected, but the vertical strips does affect the colouring of the menu.
      Ok, fair enough, I just figured since it lit up without any yellowness or obvious damage without the main plugged in, that it would be ok. Have you got any thoughts on the buzzing power supply?
        Try on a dark image -- see yellowness? Then repeat main unplugged.
        Panel has the T-con on board on this model, not user serviceable.
        • drpj23
          • May 2012
          • 528
          I realize that this model will bring up TCONs for sale but with that said, this model is usually made with a samsung panel while yours is a chi mei.
          The buzzing is probably the transformer(s) and that is normal. I know on some samsungs unplugging the main enables the backlights (it is a test procedure) but I cannot remember if it activates the rails to the main. If you have a multimeter, you could confirm this and make sure voltages are in specified values.
          But I would put some money on the main (some but not all).
          • artois7
            • Mar 2011
            • 159
            Yes - on a DVD I had playing, the blacks showed up almost entirely yellow. Could you clarify on 'repeat main unplugged'?
            Ah right, ok. I thought the board might be hiding under the metal chassis. The buzzing is really quite loud; you can hear it from the other side of the room over the sound from the TV. On this model, when you have the main unplugged, simply inserting the power cord lights up the screen. You don't have to turn the set on. Having the main plugged in with the T con unplugged results in having to turn the set on to activate the screen.
            My multimeter isn't here currently, but I will get it back soon. I actually work at a TV service centre so I'm hoping there's a main board in stock there.
              I mean, repeat with the main board disconnected from the LVDS but the TV normally powered up. To me it looks more like panel rather than main board...
              • artois7
                • Mar 2011
                • 159
                Yes, that results in a black lit up screen without any yellowness.
                  And with a black source, you get the yellow bars? Hmm...
                  • artois7
                    • Mar 2011
                    • 159
                    Not bars as such. The yellowing is more of an overall thing. The vertical bars on the screen are more of a discolouration depending on the background image, rather than one solid colour.
                    I read about a Samsung test earlier within service mode, but I couldn't find the option it was referring to.
                    The previous owner told me it happened by itself, rather than accidental damage to the screen.
                    • drpj23
                      • May 2012
                      • 528
                      The only reason I insisted main was since the text seemed unaffected which is unusual.
                      But, from the pic with the warning text, you can see a bordering affect which is usually caused by a failing TCON/panel so ya maybe I will agree...
                        Most panels have a limit to their white level which is usually set to the maximum pixel value (255) or just below it. Even a glitch can let through more light than the panel is designed to.
                        • artois7
                          • Mar 2011
                          • 159
                          I found a board at work today that is faulty and was removed but kept in storage. The board's fault suggested poor quality picture, discolour and a vertical stripe down the screen.
                          I've now swapped the boards, as I figured it would at least change the problem. I still have the vertical blocks/sections in the same places, but all the colours have changed. Black screens are now purple on the dvd player, or a grey with a border effect. The TV generally seems a bit more healthy, but still definitely faulty.
                          I'm starting to think both the main board AND the panel are gone.
                          • woodware
                            • Mar 2013
                            • 10
                            • Macedonia
                            Hi, I saw similar problem on my lcd TV. The flex connectors on the top of the panel-T-con,someone disconected earlier. But, when turned back, few of the metal connectors were distorted. When I made straight and carefully connected in T-con, the stripes were gone.
                            • netdent
                              • May 2011
                              • 208
                              I have one of these with a cracked panel, boards look same as yours, only problem is it has a blink code! Not sure if that's down to the panel being smashed or if it had a fault prior to the damage? Would be willing to sell the boards
                              Ronnie
                              sigpic
                                Samsung do not use blink codes. The LED will often continue blinking for some time after power up.
                                • netdent
                                  • May 2011
                                  • 208
                                  Ok, switches on but red led continues to blink, don't remember if it went green first lol, looked at too many tv's since
                                  sigpic
                                    Usually goes off eventually. Though I do have a 40" Sammy LCD right now -- the LED blinks continuously if the T-con is unplugged (but TV otherwise works, i.e. sound and source selection.)
                                    • netdent
                                      • May 2011
                                      • 208
                                      Will give it a try Tom, but it showed no backlight while blinking, would be handy to know boards are good, no t con on this panel
                                      Ronnie
                                      sigpic
                                        Unplug main board to power board connector to test backlight of TV. It should light up.
                                        • THXFX
                                          samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
                                          by THXFX
                                          Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
                                          I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
                                          When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
                                          What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
                                          I check capacitors and diodes and didn't find any short IN MAINBOARD.
                                          Measured all power supply...
                                          03-20-2024, 03:21 AM
                                          09-07-2024, 05:50 AM
                                        • howardc64
                                          Samsung UN55JU650DF network/streaming problem
                                          by howardc64
                                          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                          07-09-2025, 12:44 PM
                                          09-06-2024, 11:40 PM
