Samsung PS50C98HD - No picture - Video inside
    Got another lovely example of Samsung engineering (that was sarcasm by the way.)
    Old 50" 720p chassis; we have one bad cap. This bad cap has caused Y-main to throw a wobbly, blowing 6 FETs and a few resistors up. This has then proceeded to damage the upper Y-buffer.
    http://www.youtube.com/watch?feature...&v=25HTy6esBHs
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung PS50C98HD - No picture - Video inside
    I have fixed 6 of these crappy Y mains its not the cap that causes it Tom alot of the ones I have done didnt have bad caps. I think that the main point of failure is because they mounted them 5 Igbts on that tiny crappy tiny heatsink. They get very hot them Y mains do and that causes the Igbts to break down and blow on start up always on stary up is what I have found.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Im in the process of restoring a ps50q97hd now im adding fans to the Ymain as im not spending £20 on the fets. Im adding 2x 40mm fans to the heatsinks should help cool them fets make them last longer.
      • gl4709
        Samsung un55cu7000d with backlight and sound No Video / Picture
        by gl4709
        I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
        01-23-2025, 06:21 PM
        09-07-2024, 05:50 AM
      • TR103
        by TR103
        - it keeps rebooting
        01-22-2025, 04:12 PM
      • JJAAMM
        by JJAAMM
        Problem
        07-06-2023, 06:01 AM
      • alro7779
        Samsung UN55MU6103F video problem; has colored stripes on the display
        by alro7779
        Hello, everyone!
        A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
        09-27-2025, 11:29 PM
