My Element FLX-3211B TV will turn on but the screen is black and there is still sound. I opened it up and from what I can tell, the only thing off about it is that two of the round black parts (capacitors?) look like they have white stuff coming out of them. Is that enough to cause that problem? If not then what is likely the problem and what do I need to buy/do to fix it? My mother got it at Circuit City so I doubt the warranty is still valid. Any help is appreciated.
Element FLX-3211B
Tags: None
Re: Element FLX-3211B
First check the warranty - before you start any work on it.
You will need a multimeter and soldering equipment and a camera.
Welcome to the forum-
We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
Examples of what is needed
https://www.badcaps.net/forum/attach...7&d=1280167246
https://www.badcaps.net/forum/attach...6&d=1280167246
https://www.badcaps.net/forum/attach...4&d=1280167246
It will be useful if you can say a bit about yourself - skills tools etc.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
Here's the top of the boards, it's gonna take some work getting them out to shoot the bottoms. I'm a make ready maintenance worker but I have no experience when it comes to tv/computer electronics but I've installed thermostats and light/power outlets before. At the moment I only have a screwdriver and needle nose pliers, my other tools are at work. Sorry if I didn't add the pics right, first time posting them like this.
https://www.badcaps.net/forum/attach...1&d=1358719088
https://www.badcaps.net/forum/attach...1&d=1358719088Last edited by Afterlyfe101; 01-20-2013, 04:07 PM.Comment
I think those 10uF/450V capacitors are bulging; just about "PROVIEW" logo.
It's a very common issue on this chassis.
Paul678 just fixed the same model a few days ago.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Yes, those two are rounded. In the "cages" I can't tell but the ones I can feel don't seem to be rounded.Comment
Two of these should sort the TV out:
http://www.digikey.com/product-detai...1458-ND/589199
+$2.75 shipping in most of USA.
I forgot to mention all Paul678 did was to replace those caps, and it appears that several others have had this problem before.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Ok If you mean the two black components in the bottom right corner next to two red/brown rectangult ones then two bright blue in the corner then
1, they are not capacitors
2, It is just Glue.
Turning to the other board there are two caps that look bloated.
Main worry is the big cap on its side that says 25/105/V40
on it looks very bulged at the end. It needs further investigation before you continue as it could explode.
The pictures are not really clear enough - probably not taken in enough light. =Please upload pictures using attachment function when ask for help on the repair
Thanks for all the help. Okay, so if I replace those two that should fix it and if not it's something bigger? Do I need a specific kind of soldering iron and solder? Anything I need to know since it's my first time doing this?Comment
Depends on whether its a one off fix or investment for the future. Min watt iron is 25w
40w might be better or an adjustable one if they are not too expensive.
One where you can put different tips in is good.
Ideally some leaded solder 40/60 with flux in it. Some more flux and some de soldering braid about 2mm wide ( I use - other members have other preferences)
In this post there is a link to some soldering ideas
https://www.badcaps.net/forum/showpo...91&postcount=2Please upload pictures using attachment function when ask for help on the repair
Could the large 25/105/V40 cap be the problem? I can't touch it but the top is bulged, not sure if it's just the way it is but there isn't any resistance when I push it in with a screwdriver. Just tried replacing those 2 caps and no luck.
Edit:
Selldoor- I just realized you posted your concern about the big cap, I feel SO stupid for overlooking it after I read about the 2 smaller caps and thinking that would fix it. My head is in my hands, heh. So after replacing those two and it still not working, I guess I replace the big cap now and see?Last edited by Afterlyfe101; 01-31-2013, 08:45 PM.Comment
We keep running into these same power supplies either with Polaroid, Element, or Memorex sets.
Common failures are:
1. Those two caps that you replaced, make sure you put them in the right direction.
2. The intermediate fuse - green near the transformer around middle top of the board.
3. D10 shorted - this usually causes the TV not to come on at all.
With your symptoms, I find it hard to be anything other than the components in the high voltage section for the lamps or the lamps themselves. I'm shocked that since you do have sound - nobody has yet suggested that you look at the screen with a flashlight to see if you have a picture. These are the basics with this set. I've worked on a few so I know a little about their characteristics. I have one of these in my bedroom that I kept. Nice little set.The strong-minded rise to the challenge of their goals,the weak-minded BECOME HATERS
Is there a way to tell if the intermediate fuse is the problem? And I have no idea how to buy or replace the big cap (I guess it's mounted differently) or the fuse (if that turns out to be the problem), a link to the correct item in the store like tom66 provided would be appreciated.Comment
If you can depress the end of the cap it is probably not bulged - it is only the plastic disk they have put in across the end.
You can test the fuse with a multimeter or even with battery and a bulb.Last edited by selldoor; 02-01-2013, 05:18 PM.Please upload pictures using attachment function when ask for help on the repair
I hope you did install the caps in the right direction. To speak frankly, if you are unsure how to test the fuse, you should look on ebay for a replacement board. Testing the fuse is more simple than checking any other parts.
Did you do the flashlight test?
If you search for a replacement board, make sure you pay attention to the board revision. There were about three different ones that look alike.The strong-minded rise to the challenge of their goals,the weak-minded BECOME HATERS
I installed the caps correctly and I did the flashlight test and checked the fuse, still nothing. I can't find whole boards on ebay, where should I look?
Forgot to mention it hums when turned on, in case that's significant though I guess that's normal. I'm at the point where I'm about ready to wait for my tax return.Last edited by Afterlyfe101; 02-04-2013, 09:09 PM.Comment
This specification for the Lenovo ThinkPad L13 + 3YOS Warranty Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L13 + 3YOS Warranty boardview and L13 + 3YOS Warranty schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-07-2024, 04:30 AM
This specification for the Lenovo ThinkPad L15 + 3YOS Warranty Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L15 + 3YOS Warranty boardview and L15 + 3YOS Warranty schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-07-2024, 04:30 AM
This specification for the Lenovo ThinkPad L13 Yoga + 3YOS Warranty Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L13 Yoga + 3YOS Warranty boardview and L13 Yoga + 3YOS Warranty schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-07-2024, 04:30 AM
- Loading...
