Samsung LE32B651 - sound and no video
  • flyone
    • Oct 2011
    • 10
    Hello
    When I start my Samsung TV all is ok but time to time in a ranomly basis backlight switch off, sound is ok and I can see the picture on the LCD panel with the help of a strong external light source. When this problem occurs i have to switch off / on the TV to get the picture again.
    Since 2 or 3 days the problem is getting worse et I cannot use the TV anymore.
    Here are some pic of the board inside.
    what can i di to fix this ?
    thanks for your help !
    Re: Samsung LE32B651 - sound and no video
    Which country are you located in? 115V or 230V mains?
    The transistor QP801 has got very hot. This could cause its solder joints to crack, which would possibly cause lack of backlight. I advise you resolder all of the transistor solder joints and see if the issue persists. Cold solder joints are a very common issue with Samsung TVs.
      It's your lucky day, I have schematics for BN44-00261A and BN44-00261B.
      My SM site hosts these and I still have FTP access to it. Hopefully main site will be up by tomorrow...
      • flyone
        • Oct 2011
        • 10
        Hello
        Thanks for such a quick answer !
        I'm in France where the main voltage is 230 V
        I'm going to resolder these transistor right now, i'll keep you in touch about the result.
          Just remember to do them all, it'll only take a few minutes, and this will ensure that you won't encounter future issues. If you can, use leaded solder.
          Where I said QP801 I meant to say QP802S.
          • flyone
            • Oct 2011
            • 10
            Works done...
            I have good trust in this soldering job because the tv is in much more better condition than this morning. I hope it was just that. I'll come back in a few days to make a report.
            Thanks again for the advice
              I hope it resolves your issue.
              • gl4709
                Samsung un55cu7000d with backlight and sound No Video / Picture
                by gl4709
                I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
                01-23-2025, 06:21 PM
              • Max514
                Samsung UN55H8000 sound but no backlight no video
                by Max514
                Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
                The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
                I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
                • Unplugging the main board cable at the power supply >>> backlights came on.
                • BLU_ON signal from the
                04-14-2022, 10:34 AM
              • soeren
                A2442 - No sound over internal speakers and no video playback
                by soeren
                I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
                All happened after the battery ran out of power overall several days when I was on vacation.
                I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
                07-26-2024, 01:24 AM
              • jchang
                Samsung UN70NU6900F no picture and no sound
                by jchang
                Hi all
                I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                Symptom:
                No picture no sound.
                When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                No sound at all.
                What I tried:
                1. I tried unplugging the left or right ribbon...
                01-09-2023, 06:28 PM
              • Ierwin
                by Ierwin
                05-13-2025, 03:31 PM
