Help with 26LG30-UA
Re: Help with 26LG30-UA
How do those voltages look? Anything off? Is that polarity change a red flag or is that normal?
Thanks!Comment
Didn't notice this post. Those voltages look fine to me. I doubt they would cause the issue.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I had this same model with a video issue that got better with the TV being on for awhile, determined it was the main board but never tried reflowing it, I think that may be the case here.
Never tried the oven thing because I didn't know about it, Tom can tell you how to do it..Comment
Interesting thought. I haven't tried just letting it sit on for a while.
I'm all for reflowing the boards even just as a "what the hell" possibility.
In this case, which one is the "main" board you refer to? Is that the power supply? The t-con? The one with the tuner and video inputs? or the one which i'm speculating has to do with power inversion for the display?Comment
Main board is the one with video inputs on it.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Reflow is best done in an oven. The one used to cook chips and pizza on a late student night.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
i considered that, but i hate to fill up my nice food oven with all that nasty off-gassing and toxic chemicals and whatnot...Comment
not to mention fear of melting things! lol has anyone ever successfully reflowed in a toaster oven?Comment
Well, in a desperate attempt to avoid a reflow, I replaced the t-con. Sure enough, the unit starts right up!
Thank you everyone for your help!!!Comment
by rouninHi everyone,
I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
🛠 Original Issue
The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
⚠️ New Problem: One USB-C Port Only Works in One Orientation... -
by ugamazingI have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre... -
by elmarkHP Pavilion 15-CW1002UA
S/N 5CD0251CBC
P/N 7KE54EA
Hello guys!
I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
It powers on OK and has no other issues except the following:- CAPS LOCK does not work at all
- Fn button toggles Flight Mode
- When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
- (with SHIFT pressed: 't%' and 'y^' respectively)
but when I press and hold...06-27-2025, 01:10 AM -
I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
To assist with troubleshooting, I'm attaching two power circuit schematics:- Power
by wizard13Hello everyone,
I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
I have checked the forum and the available documentation but could not find a solution specific to my issue.- Brand & Model: Dynabook Satellite Pro C50D-B-100
- Part Number (P/N): PYU13E-00C00PFR
- Serial Number (S/N): 22028896H
- System Configuration (SC): A1PYU13E1127
- Motherboard Model: IP3_ACN16_MB_V21_20211222A
- Power Input: DC 19V –
Channel: BIOS Requests ONLY!
- Loading...
