I was excited to spend 20 bucks and fix a multi hundred dollar tv.
the TV initially lost sound unless you left it on for 5 min then turned off and right back on. then next week even the standby light went out.
I got a kit with all the needed caps. I didn't see a single one that looked bad on the primary side of the psu but still replaced any large ones (aside from the hugest one which the kit seller said hardly ever goes bad)
It appears only the secondary side had bad caps. Again, regardless I replaced any I could. I have 4 or 5 tiny caps that I was afraid to mess with due to the circuitry near them being pretty tightly packed. My solder iron tip isn't what it used to be ... its ready for the dumpster really....
None of the tiny caps looked even slightly bad anyway.
Plugged it back it, the standby light is back. Turned it on, the initialization screen shows for a fraction of the time its supposed to then the screen and backlight both go out. Standby light does not come back on though. I left it "on" for an hour and then turned off and one quickly, no joy. turn it "off" and standby light comes back on.
I did find two modules that seemed to relate to the LCD on either side of the LCD, one labeled master the other slave, they each had 2 470's that were obviously blown. They were surface mounted on the board, no holes, just puddle of solder and goo on the sides of the cap to hold it in place Replaced them, did a GOOD job replacing them, but symptoms unchanged.
At a loss here, did I fail to solder something properly? the tiny caps dead?
Could I have cooked a diode or something near one of the caps?
I read sometimes it the invertor... is that the transformer on the psu board? Where can I get a cheap esr meter to investigate these caps and how can I tell where I may have just not had enough heat on my iron? (is there a meter I can use rather than just waste a bunch of de-solder?)
Andrew
Andrew
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
