VIZIO VP322 HDTV10A has no video and won't power up completely.
  • DRYSKULL
    • Dec 2012
    Replaced the nine capacitors that came in the kit shown in the red square, plus a 470 uf next to the header in the upper right of photo.
    Symptoms;
    VIZIO emblem is amber when cord is plugged in.
    VIZIO emblem turns white when powered on.
    Small green LED flashes (on small PCB below the Power Supply PCB) when power up sequence is started.
    Black relay (upper left in photo) on power supply energizes for a short period then then de-energizes. Green LED stops flashing.
    During power up sequence getting the 16.5 and 12 VDC on the header in the red square of the picture. Always has the 5 VDC coming from the Video signal PCB to the right of the Power Supply PCB. Also have 5 VDC on the header in the upper right of picture.
    All fuses are good - standard fuses and pico fuses on all PCBs.
    Without a schematic I cannot tell where to go from here. I don't see any blown caps or arc marks or anything. This is a fun project and would appreciate some help. Have DVM ready to test whatever...
    Thank you.
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • mrtek
    Vizio M65-C1
    by mrtek
    Hi.
    picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
    When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
    This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
    07-14-2025, 07:28 PM
  • stefanpng
    HP EliteDesk 800 G1 SFF solder an extra fan header?
    by stefanpng
    So the HP EliteDesk 800 G1 SFF has only one fan header on the whole motherboard, a 4 pin cpu. There is a second chassis fan header, but it is not installed, there are just 4 bare through holes and some silkscreen.
    Other models like the tower version of this computer have the chassis fan header installed, so I was wondering if it was possible to solder in a new 4 pin header.
    There is some surrounding circuitry, and I think it is identical to this schematic. The CPU fan header circuitry matches exactly except for one filter(?) cap, and the chassis...
    07-13-2022, 05:54 PM
  • howardc64
    Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
    by howardc64
    Failure Symptom
    No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
    Where is the short?
    Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
    Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
    05-27-2025, 02:56 PM
  • goofykao@yahoo.com
    ViZIO M70-D3 Completely Dead (Weird!)
    by goofykao@yahoo.com
    Hi, Just joined this forum hoping to fix this TV.
    Sorry for the long post to explain the problem in details.
    Model: VIZIO M70-D3, 4 years old
    What happened: TV had no issue at all and one day just died (4 weeks ago) and NO LED stand-by light (usually it's Red at bottom left front side)
    Current status: Cannot power on and NO LED stand-by light
    Strategy: Since I am not good at fixing boards at component level, it's better for me to just replace boards with known good ones
    Trouble Shooting History:
    09-27-2021, 08:42 AM
