First plasma, LG 42PC5D. Sound but no picture. Help me make sense of this.
  • johnboy1313
    replied
    Re: First plasma, LG 42PC5D. Sound but no picture. Help me make sense of this.
    Originally posted by tom66
    Can't see a problem. I would expect the panel to glow with everything it is given...
    I wish I knew more about this. Everything I've read says that the output from the boards should have looked odd, due to overworking, if the panel was bad. These boards do not appear to do that.
    I've got that Panasonic plasma that I've posted about in another thread. Even when that set would not power on, I could clearly see the panel prime, even in a lighted room. This set does not do anything like that.
    I just don't get it.
    replied
  • johnboy1313
    replied
    From the top right pin. I can't think of anything else but the panel.
    replied
    You could call this the digital board. It is essentially the same as a T-con in an LCD TV.
    Try scoping that top right pin.
  • johnboy1313
    replied
    Back to this one. I've had a few sets on the bench this past week that kept me from parting this one out. I'm still not ready to say the panel is bad. The evidence just doesn't support it. I worked on a Panasonic plasma this week and if anything the buzz emitted from the LG is quieter than the buzz emitted from the working Panasonic panel. I will attempt to get the scope again tonight.
    That looks like a factory mod to me.
    Top right pin might be the clock.
    I assume you are saying I should scope the top right pin. Is this correct? Is this board also called the digital board? In this link, posts 11 and 13, a member going by the name randtek outlines a procedure for testing the digital board.
    replied
  • johnboy1313
    replied
    Sorry it's taken so long. My interest in fixing this has dropped off a bit lately.
  • johnboy1313
    replied
    Here's the control board. I think it's been worked on too.
    replied
    Depends -- if you find it, post a picture. I can highlight the oscillator output pin.
  • johnboy1313
    replied
    What am I checking it for? How am I checking it?
    replied
    Typical appearance (left), bottom of device (right):
    http://www.sz-wholesaler.com/userimg...llator-701.jpg
  • johnboy1313
    replied
    What's the oscillator look like? I had to bring the scope back this morning do I need to get it again?
    replied
    It was directed at both.
    The Vsetup ramp is that rising voltage captured on the scope.
    All other timings are correct.
    As far as I am concerned the control board is sending all the right signals and the Y-sus and Z-sus are properly interpreting them.
    Check the oscillator on the control board -- it's usually underneath the main board on this chassis.
  • johnboy1313
    replied
    Originally posted by rayrod81
    If the logic board has been worked on then that could be the fault. The oscillator is what produces the signal to turn on the panel drivers. If that is not present then you would get the no picture fault. It should output a 100MHz sine wave. If that is not present then that is your problem.
    Edit: It looks as though that might be the Main Board but it is hard to tell with out seeing the whole board. Either way I would check the oscillator on the logic board.
    Yeah, it's the main board. What's this oscillator look like?
    There should still be pre-discharge from the panel if it's getting the Vsetup ramps though. And the Y-sus and Z-sus won't generate the right outputs without correct timing.
    Is this directed at me? I haven't any idea what it means. Sorry
    replied
  • rayrod81
    replied
    replied
    3.4V_ON just turns on the 3.4V output, so it's a logic signal around 0V off, 2~5V on.
  • johnboy1313
    replied
    Looks like this one has me beat. I'm not going to throw good money after bad in an effort to fix an antique anyhow. So with one last effort to hit it out of the park, I'll post this.
    The top pin of connector P800 labeled 3.4V_ON shows 4.75V when on and 0V when off. Does that mean anything to you? I will be parting this one out with the assumption that the panel is bad if I haven't figured anything out by this weekend.
    replied
    I can barely here any buzzing, but it's almost always continuous and very loud. All plasmas emit a very slight buzzing in operation.
  • johnboy1313
    replied
    I rechecked the regulator on the main board. I either misprobed it or didn't remember it right because it has 5v at the center pin now.
    I think it's gotta be the panel. I just unplugged the ysus and powered it on and there is absolutely no buzzing before the speakers come on. Did you watch the video I made? Coul you hear the buzzing?
  • LEECH666
    Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
    by LEECH666
    Good day ladies and gentleman!
    I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
    This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
    I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
    01-19-2024, 05:46 PM
  • KYBOSH
    Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
    by KYBOSH
    Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
    No picture but you hear the TV static (white noise) playing loud and clear.
    The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
    But it seems they didn't get too far and just left it.
    When I first took a look I was amazed at how pristine the inside looked.
    Its as if the TV had been in a time capsule.
    Caps looked like they were just pulled off the self.
    Copper coils had no sign of corrosion on...
    02-01-2023, 11:10 PM
  • SluggerB
    LG Plasma (PDP50R10101) No picture No sound
    by SluggerB
    This is my first Craigslist freebie fix attempt. 50 inch LG Plasma TV Previous owner said over time it was struggling to turn on, it would take 4-5 times to turn on, the one day it just did entirely. I took it home and plugged it in, I her a click, then a second later another click, and nothing. Dead as a doorknob
    So I took the back off and check voltages. The power supply appears fine, I checked the VS, VA, and 5V voltages and they all measured correct, on the power supply board and on the display boards (Y and X boards). All the fuses are fine
    Following a YouTube videos...
    12-03-2022, 09:10 PM
    HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
    This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
    09-12-2024, 02:30 PM
    HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
