Samsung LE26B450C4W Dead PSU
  • windy1603
    • Dec 2012
    • 4
    After some help with this TV. I got the set from an auction and it is dead with no signs of life. The set has the BN44-00259A PSU fitted. I have done the usual checks and found that the second main fuse FM802S was blown, a closer check of the board i found that UM801S (ICE3BR0665J) had damage to pins 3 & 4 (looked like shorted with a test probe by others).
    Replaced the IC and checked all diodes etc (only have access to standard DVM at moment) and all checked out. Replaced fuse and powered up set still dead but fuse now intact. Checked out voltages on large cap as another thread https://www.badcaps.net/forum/showthread.php?t=21816 on here and getting 600V also getting 230V at FM802S fuse. No voltages at any pins on output header.
    I used to work on some digital stuff in the past but not great on SMP's so any help would be great.
    No obvious damage to track side of board pic below of PSU
  • windy1603
    • Dec 2012
    • 4
    Re: Samsung LE26B450C4W Dead PSU -* Fixed *
    Set now working Appears zener diode ZM801 was spiked (and was shorting internally) when UM801s pins were shorted or had failed (and they killed ZM801fault finding).
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      600V?!
      Has that filter capacitor blown up yet? It's only rated for 450v!
      Good job on the repair, you didn't need our help at all!
      Muh-soggy-knee
      • dpijl10
        • Oct 2014
        • 5
        • The Netherlands
        Hi windy, I have the same defect on this PSU. I have ordered a replacement IC, but I cannot read the numbers on the ZM801 diode.
        The symbol states a zener-diode, and it starts with 1N and ends on 47A, but in between something like 4? (stil 10 combo's)
        Can you remember or look up the correct type for that diode?
          dpijl10: bn44-00259A diagram.
          1N4740A, check the OPTO PC801 also.
          • dpijl10
            • Oct 2014
            • 5
            • The Netherlands
            Thanks very much budm - also for the schematics! This will help me fix this psu
            • dpijl10
              • Oct 2014
              • 5
              • The Netherlands
              Just to let u know: The PSU is alive again - a new fuse, new controller (ICE3BR0665J) and new zener diode 1N4740A. PC801 is fine (no replacement done).
              Total cost: € 2,54
                09-07-2024, 05:50 AM
              • jesterace
                Samsung UE46ES8000 Blown fuse but no other signs of short
                by jesterace
                Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                09-11-2024, 03:14 PM
              • Pwtzz
                Samsung 55NU6900 - Heard a pop then tv is dead, burnt cap & dead fuse
                by Pwtzz
                Hi All,
                Before replacing what I know to be bad even with my novice experience. What I have checked at the moment is the fuse and the obvious burnt capacitor. I haven't bought any replacement parts yet.
                I still have no idea how this happened but could just be plain old turned bad. What other stuff should I consider buying as replacement? thanks in advance.
                Edit: I saw that a replacement board can be had for about $50. I would rather attempt to fix before just replacement the board.
                07-19-2022, 06:45 PM
                09-06-2024, 11:40 PM
