Magnavox 42MF437B/37 Blowing Fuses after "Professional" Repair
  • briankb
    • Nov 2012
    • 18
    Re: Magnavox 42MF437B/37 Blowing Fuses after "Professional" Repair
    I removed the bridge rectifier and performed the test as shown in the video. My results were the same as the video so I assume this bridge rectifier is good.
    What should I check next?
    • Mr Bill
      • Nov 2011
      • 648
      Are there any other mosfets on the board (Q)? You might just need to replace the W26xxx and the fuse and that'll be it. If you order the mosfet get the few remaining caps the "pro" didn't do before. All but the big 450v one. From your picture in post #1 i can see at least 1 capxon and 2 lelons.
      • briankb
        • Nov 2012
        • 18
        There is a small one without a heat sink (I think) at Q908 (right of the 450v cap). I flipped the board over and tested what I think are pins 2-3 and I get a reading in both directions.
        Isn't the 450v cap a lelon? What's the reason for not replacing it as well? Just curious so I can learn more about these things.
        • Mr Bill
          • Nov 2011
          • 648
          Q908 you'll test like you did the W26xxx mosfet. Meter in the ohm setting, 1-2, 2-3, 1-3. Anything under 30 ohms is considered shorted. I think your trying to test it like a diode. The large cap doesn't endure the stress the little one do and they rarely fail (but can).
          • briankb
            • Nov 2012
            • 18
            You were right I did test it like a diode, I did it again and it failed.
            I will double check these tomorrow and check what other caps I need for a order.
            Thanks for your considerable help!!!
            Were all of these tests just from experience or is there a method to tracing these things down? Or do you just test all of these diode,mosfets, ect... until you find something fail?
            • briankb
              • Nov 2012
              • 18
              thanks to this thread and wikipedia I understand what a bridge rectifier does and how it works. very cool. two men enter one man leaves :-)
              http://en.wikipedia.org/wiki/Diode_bridge
              • retiredcaps
                • Apr 2010
                • 9271
                #27
                When a fuse blows, there are certain main suspects that need to be checked. Namely, the bridge rectifier, the power mosfets and diodes. If any are shorted, they will cause the fuse to blow.
                --- begin sig file ---
                --- end sig file ---
                  Schematics, it should match your 47".
                  Do you have the chassis number as printed on the tag on the back of the TV?
                  • briankb
                    • Nov 2012
                    • 18
                    Thanks for that schematic! It looks just like my board. I replaced Q908 and the mosfet just above R927 in the photo. The fuse did not pop as far as I could tell, but I still need to pull the fuse and test it. It's a slow blow white ceramic fuse and I'm not sure if those show visual signs if blown.
                      Usually ceramic fuses don't burst or show any signs of failure (they are much safer than glass fuses which can burst), they just test open. However, if it did blow, there would usually be an audible pop and bright flash from the fuse.
                      • briankb
                        • Nov 2012
                        • 18
                        Thanks for that bit of info. Because it didn't blow on the test table I installed it back into the TV. I will pull it out again and continue testing in a few weeks.
                        • Anton johnson
                          • May 2013
                          • Bahamas
                          #32
                          I have e same tv and problem but the repair guy said that I needed a new power supply board. My question is that I have a dark shadow in the background, like the backlight is blown in some places, what could be the cause of it
                            That is MURA due to LCD panel fault. Not repairable, and nothing to do with the power supply.
                            e.x. http://cdn.avsforum.com/f/f6/f6b2a69...ach152841.jpeg
                            Only applies on TVs using cheap ChiMei and Chungwha panels, which a lot of manufacturers use to cut costs.
                              How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                              by sam_sam_sam
                              About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                              Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                              Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                              12-14-2023, 07:45 PM
                            • Sik_6ty_Sixx
                              HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                              by Sik_6ty_Sixx
                              So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                              02-18-2025, 05:06 AM
                              Surface Mount Fuses Fundamentals Datasheet
                              TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                              TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                              10-07-2024, 06:07 AM
                              1970 Metal Lathe Control Circuit blowing fuses on the 120 volt section failing meager test below 60 mega ohms
                              by sam_sam_sam
                              I was working on this machine yesterday and I now going to use an incandescent lights instead of a fuses to figure out what the issue is with it blowing control voltage rail but this not the only issue the coolant pump failed the meager test as well as the main motor as well this motor has 12 motor wire leads instead of the normal 9 wires
                              This metal lathe has a weird motor setup it has a soft start motor with a ā€œYā€ and a delta type of motor winding setup and it is not done in the motor pucker head enclosure it is with four different contactors wired in a configuration I have not...
                              12-29-2024, 07:18 AM
                            • mon2
                              Gemsound PAX-105 Audio Amp blowing fuses
                              by mon2
                              Hi. New to this side of the forum.
                              Have an audio amp (Gemsound PXA-105) that keeps blowing the 3A fuses upon power up. Owner stated that the amp was on when he plugged in the input (mixer board) and that started this chaos.
                              Would a schematic be available? Advice on what to check? Power supply / output amp transistors? Do see the power on green led turn on for a brief moment before the fuse blows.
                              Thanks.
                              10-30-2024, 08:33 AM
