VESTEL 4215 HD - Flickering screen
  • Fvandier
    • Nov 2012
    • 9
    • Belgium
    Good evening.
    I have a Vestel 4215 HD (Plasma) of which the image started flickering something like 3 to 4 weeks ago. As days go by the flickering gets worse and worse. Where initially the flickering would go away after a couple of minutes, it now stays.
    The flickering appears to be mainly present in the larger lighter (white'ish) areas of the image.
    Any idea which part/board might be causing that and how I could remedy it?
    Thanks in advance for any good advice.
    I have recorded some video if that would help.
    Kind regards,
    Franky
    Re: VESTEL 4215 HD - Flickering screen
    I have never actually seen a "Vestel" branded TV. I knew they stick other peoples' names on their TVs but didn't think they sold them under their own name. Vestel have a bit of a reputation here as being "inferior"... to put it lightly.
    The first step is to take pictures of your TV's internals. This is best done using sunlight and a half-decent camera.
    We have seen plenty of Vestel flickering issues on LCDs, it is usually down to failing poly-capacitors. It would be interesting to see if Vestel based plasmas have the same issues.
    • Fvandier
      • Nov 2012
      • 9
      • Belgium
      Here's the video of the flickering, and then of the electronics (on 90 degrees angle - sorry about that)
      http://www.youtube.com/watch?v=ra0tL...ature=youtu.be
      Kind regards,
      Franky
        Do you mean the slight pulsating on the video? I can't see much flickering.
        It has an LG 42X3 or 42X2 panel but I have never seen one of those flicker before, it also uses the LG power supply which has decent capacitors on it. The only thing Vestel about this is the main board.
        • Fvandier
          • Nov 2012
          • 9
          • Belgium
          Hi Tom,
          It is flickering badly.
          I'll see if I can make a better video.
          Like I posted above, it is mainly when the image has a lot of white/light colours.
          Kind regards,
          Franky
            Most older plasmas flicker quite a lot with a brighter picture. Some people can see it more than others. It may be normal behaviour. I can't explain though why it would get worse over time though...
            • Fvandier
              • Nov 2012
              • 9
              • Belgium
              Here is a better video of the flickering image.
              Can't really look at that a whole evening without getting a headache.
              The flickering occurs independently of the video signal source (scart or HDMI).
              http://www.youtube.com/watch?v=mhrd5...ature=youtu.be
                If I were to suggest a fault, it would be those two 450V caps... but I'm half suspecting that's normal flicker, and something in your environment has changed to make it more noticeable... it's very hard to tell.
                BTW, try your camera in bright light. The shutter will open for a shorter period, so the flicker might be more obvious on video.
                Another thing to check if you can is the Vs voltage. It should be around 190V for this generation of LG plasma. Check if it's dropping too low on a multimeter, if you have one available.
                • Fvandier
                  • Nov 2012
                  • 9
                  • Belgium
                  Tom,
                  Thanks for your reaction.
                  It's not something in my environment that changed. It really is a very distinctive constant change in luminosity of primarily the light areas in the image.
                  I'll see whether I can measure the Vs.
                  Kind regards,
                  Franky
                  • Fvandier
                    • Nov 2012
                    • 9
                    • Belgium
                    I've been reading some more posts - thank you Badcaps Veterans - and found a swollen 470microF 35V capacitator on the power supply board.
                    Guess this might be the problem source?
                      Yeah, that could easily be the problem. Whereabouts is it?
                      • Fvandier
                        • Nov 2012
                        • 9
                        • Belgium
                        I have replaced the faulty 470/35V capacitor by a brand new 470/50V capacitor and the flickering has disappeared.
                        However I now have small red and green pixels in the image (when looking closely). I've read in this forum that I need to tweak something to get rid of that. What do I have to do and where do I find that on the boards?
                        Kind regards,
                        Franky
                        • Fvandier
                          • Nov 2012
                          • 9
                          • Belgium
                          Tom, there is a small board behind the metal plate on the right lower side of the TV (when looking from the back side). That's where I found the swollen capacitor.
                          Thank you for the interest you show.
                          Kind regards,
                          Franky
                            Do you see Vset_up and Vset_dn (sometimes ramp_up or ramp_dn) on the large left-hand board (looking from the back of the TV)?
                            • Fvandier
                              • Nov 2012
                              • 9
                              • Belgium
                              Tom,
                              I have a setup and a setdn on the YSUS yes. What should I do with them?
                              Rgds,
                              Franky
                                Carefully tweak setup one way. It doesn't matter which, but watch the image carefully. Better, worse? If it gets worse, reverse the direction. Do the same with setdn.
                                • Ado02
                                  Lenovo Thinkpad X1 Gen 10 - Flickering Screen
                                  by Ado02
                                  We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the IntelĀ® IrisĀ® Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
                                  The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...
                                  12-16-2024, 02:33 PM
                                • classypenguin
                                  TV Telefunken (Vestel) D50U660R2CW - on the tv screen but every 3-4 seconds lines appear on the screen flickering
                                  by classypenguin
                                  Hey, I got an Telefunken 4K D50U TV in for repair. Since the problem is t-con flex related, I isolated the problem to one side (right flex of the t-con). I taped the flex a bit, but i couldnt get any further. I attached the pictures of the t-con board in zoom in perspective. I would appreciate help for this TV. Please note that I came from Germany, so it is a bit difficult with the time zones. Greeting Tobi...
                                  08-29-2024, 03:47 PM
                                • Ryan.man
                                  by Ryan.man
                                  02-04-2025, 12:23 PM
                                • survivalbloke
                                  HP ENVY HP 13-aq1013dx - screen flickering black if using touchpad or external mouse
                                  by survivalbloke
                                  SN: 8CG0213H8W
                                  ProdID 3C311UA
                                  This device came in due to the screen flickering if you use the touchpad or external mouse. It will flicker black when this occurs. If you use the touchscreen, the behavior does not appear. Also, if connected to external monitor, the external monitor is not affected by the flickering. I did a good amount of research on this, and concluded that it is due to the display driver. HP does not offer Windows 11 drivers for this model so I got the replacement drivers direct from Intel. I installed them and the problem...
                                  05-08-2025, 12:21 PM
                                • smic717394
                                  by smic717394
                                  07-25-2024, 10:16 AM
