Panasonic TC-P42X2
    Re: Panasonic TC-P42X2
    The low 165V also seems really suspicious to me. Maybe the TV was hit by a surge.
    • IamCanadian
      • Nov 2012
      • 119
      I checked v at all the optos all have 5v on the secondary side but ! has 11v
      I will take good pics of the PS
      • IamCanadian
        • Nov 2012
        • 119
        Had to use flash, But everything is visible, Let me know if you want to see the foil side.
        Optical closest to the center was 10v on the upper right leg.
          So, if you CAREFULLY tweak the Vsus adjust pot, does Vsus change?
          I had a plasma TV which would display a faint image down to 130V on the Vsus, so I think sometimes else is up, but there is the possibility if it is designed for a high ~210V it might not show anything on 165V. Here's where you may need to use that scope .
          • IamCanadian
            • Nov 2012
            • 119
            see that is the thing, the PS treats the SN as a dead short when it is not. with SN plugged in and for the brief moment that the vsus powers up I measure about 1v then the psu shuts down the vsus relay.
              Ah, that's where it gets tricky, because this set doesn't have removable buffers. But you can still tweak Vsus with them disconnected.
              • IamCanadian
                • Nov 2012
                • 119
                Wish I had the means to load test this ps first, and vsus info on the panel would be great too
                  A 120V, 100W light bulb would be a good load. It might not last very long on 165V, but it could do a temporary job. Are those illegal in Canada yet?
                  • IamCanadian
                    • Nov 2012
                    • 119
                    lol nope not outlawed yet, But I suspect soon. I will try it, not sure if I have jumpers I would trust at that power though.
                      Solder to the light bulb and insert wires into one of the connector ends, the end which would normally plug into the SN. Tape all the wires up so you can't easily electrocute yourself.
                      Measure the cold resistance of the bulb first; it needs to be at least ~165 ohms to ensure it doesn't load it down too much.
                      The set will still shut down without working SN or SS due to 6/7/8 blinks error but it will run usually for about 1.5-2 seconds.
                      • IamCanadian
                        • Nov 2012
                        • 119
                        Just added a TCP42S2 to my collection.
                          What, another plasma?
                          • IamCanadian
                            • Nov 2012
                            • 119
                            It was the Garbage or me..the guy chose me
                              Man you are lucky if you can't get the X2 working you should be able to get the S2 working right? Was it free? I only once got a crappy 42 inch LCD for free. Everything else I paid for.
                              • IamCanadian
                                • Nov 2012
                                • 119
                                yup free! Hope to get one of them working.
                                  I'm sure you can get both working, open a new thread on the S2 when you're ready, I'll try and find a manual for you.
                                  • IamCanadian
                                    • Nov 2012
                                    • 119
                                    I have the training manual for it. but I will for sure.
                                      Do you need the service manual? I'll find and upload that tomorrow when I get a chance. Late now...
                                      • IamCanadian
                                        • Nov 2012
                                        • 119
                                        SM would be good, no rush Thanks again for all your help!
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          11-20-2024, 08:52 PM
                                        • AquaMan Ua
                                          Problem with PANASONIC CF53 laptop after changing BIOS settings
                                          by AquaMan Ua
                                          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                          05-17-2025, 09:40 AM
                                        • signal.quest
                                          Panasonic TC-P42S30 - Solid RED LED - No Blink
                                          by signal.quest
                                          Hello. I am hoping the very smart helpful people of this forum can help me repair my TV. Here is the history of the what I have done so far.
                                          I was given the TV by a friend who was going to throw it away because it did not work.
                                          The TV definitely had a bad TNPA5349 board that was shorted across the power input. I sent it to a repair service on ebay and was told it was rare case and not repairable.
                                          I then bought a refurbished TNPA5349. Before installing it I checked for a shorted power input and it was good. I installed it and powered on the TV. I could...
                                          02-01-2021, 11:01 PM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • stecos
                                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                          by stecos
                                          Hi everyone!
                                          I happened several times, in the search for help from the web, to consult this very interesting forum.
                                          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                          Having said that I come to the gist of my post on the forum as the title suggests.
                                          For my passion for technology I'm now collecting several...
                                          11-28-2022, 11:39 AM
