Panasonic TH-50PX60U 7 blinks
    Re: Panasonic TH-50PX60U 7 blinks
    Originally posted by ruatha65
    Unfortunately, the repair courses you provided have a file extension I can't open. Tried to unzip them, but no luck. Unless you believe I'm wrong in my diagnosis of a bad P board, I'm going to go ahead and order a replacement.
    Use 7-Zip (free, open source - http://www.7-zip.org/) to decompress RAR files.
    • ruatha65
      • Nov 2014
      • 12
      7-zip worked perfectly. Thanks Tom! Does anyone have a recommendation for an online parts supplier? I've already purchased and installed a switch board from AllProTvParts.com. (I originally thought the switch was the issue, since my kids kept pushing it instead of replacing the batteries in the remote). However, with something as complex as a P board, I'd rather have a proven source.
      • ruatha65
        • Nov 2014
        • 12
        Those tutorials are amazing! I am apparently such a newbie to this that I didn't realize a P board replacement was more than just a "plug and play" operation.
        • tw2005
          • Oct 2011
          • 6458
          I must have been looking at an older guide. According to your thumbnail, my issue is clearly a bad P board, as there are 0v at pin 1 of PA40.
          I'm apparently so new to the forum that I cannot yet start a new thread. I will be more than happy to do so once I'm allowed.
          I haven't yet looked at the guides contained in your second post, but I will, just to be absolutely certain my diagnosis is correct.
          Thank you for the quick and on point advice!
          I can't be sure if that guise is 100% accurate either, I has it saved as PX60 but the front cover picture looked like a newer model now that I looked at the powerpoint presentations.
          No idea if it's P board or not, hopefully you can apply the info and fault find a bit deeper
          • ruatha65
            • Nov 2014
            • 12
            The only powerpoint that deals with diagnosing my model is Lesson 4, and that one only has one page for an SC board fault, which does not have the symptoms of my unit. I think I'm going to take a leap of faith and go with a new P board. Worst case scenario is a misdiagnosis and then I'll most likely need a DG board. I'll still pick up some knowledge and be under the cost limit I set before I give up and buy a new one.
            • Andre Gilbert
              by Andre Gilbert
              11-20-2024, 08:52 PM
            • jm1234
              Panasonic plasma TX-P42ST50 - 6 blinks
              by jm1234
              anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
              It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
              I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
              I checked that board for any obvious faults...
              05-22-2024, 06:59 AM
            • Alicat
              Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
              by Alicat
              Stopped by this site trying to fix my parents Panasonic Plasma TV.
              Model number is TH-50PZ85U
              Power comes on and the red power light stays on solid.
              Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
              I also hear a few clicks.
              I also think my parents said there was a thunderstorm and the TV failed after that.
              Section 6 in the service manual talks about power and no screen,...
              10-30-2024, 10:09 AM
            • CrewmanRedShirt
              Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
              by CrewmanRedShirt
              Hello all,
              As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
              07-13-2024, 11:02 AM
            • nobbnobb1
              Panasonic TC-P50U50 Powers Off - 8 blinks
              by nobbnobb1
              I have a Panasonic TC-P50U50 plasma TV which powers on briefly, then powers off and flashes the power light with 8 blinks. This TV is infamous for this, of which the suggestion that the SS board has failed due to loose grounding screws and requires a replacement of the following components on the SS board:
              2x DG302 (Q16051)
              2x RF2001 (D16041)
              2x 5.6 ohm SMD resistor
              1x BD8694 IC
              I have already gone ahead and replaced these components, as well as cleaning off the ground connections on the SS board as well as the associated...
              03-21-2023, 08:33 PM
