Plasma sony ke-p42m1 does not display nothing
  • conan981
    • Aug 2011
    • 72
    • ITALY
    Hi, i hope someone wants to help me in repairing this elephant i had for several months in garage.
    Main fault is that TV does not display nothing (not even backlights are ON)
    BUT led that is indicating that TV is on is GREEN.
    (when you connect the 220v AC to TV led is RED, when you push power button led goes green)
    Sometimes after 20 or 30 PUSH UP/DOWN of power button the tv GOES ON and is working OK..
    Now, i found also SERVICE MANUAL of this TV that is downloadable HERE
    https://cdn.badcaps-static.com/pdfs/...6e1dd1037b.pdf
    with all the schematics and all the needed for repairing this, but i have only a little knowledge so i hope someone wants to guide me in repair.
    I found that G1 board (this tv has 2 POWER SUPPLY BOARD) is working OK testing the voltage for the IN- connectors and the OUT connectors.
    Found also that the backlights doesn't go on because there is no 170V (DC)
    in CN6111 and CN6112 connectors.
    Now, why there is no 170v?
    I think that at page 33 of service manual there is the answer but i am not capable to understand what to test..
    thanks for all the help you can provide me
    Conan
    ps. i don't know if are needed the same (having schematics) but here are some pictures of G2 board.
    if needed i can make photos of the rest.
  • drpj23
    • May 2012
    • 528
    Re: Plasma sony ke-p42m1 does not display nothing
    Which 170v: Vs, Ve, Vset?
    And yes, could you please take an overview shot of the whole back.
    And then a more direct overview of the power supply.
    All with no flash but ample lighting.
    • conan981
      • Aug 2011
      • 72
      • ITALY
      Here are the photos of the whole back of tv.i hope they are fine otherwise let me know.
      All the three.. i can measure VS = 6V , VE = 6V AND VSET = 5V
      But i checked and 370V enter the g2 board. Maybe there is something like a stdby relay or similar that make the tv not switch to full on?
      • gilly1984
        • 751
        Blast a hairdryer on the power supplies before turning it on.
        Does it switch on?
        Do NOT touch heatsinks when testing for voltages as they may be LIVE!
        • conan981
          • Aug 2011
          • 72
          • ITALY
          @gilly1984
          heating G2 power supply board the LCD PANEL goes ON!!
          what should i check?
          thank you
            Cold joints! Older Sonys were well known for it. Re-touch any suspect solder joints. Try narrowing down heat location.
            Oh, and minor nitpick: there's no LCD panel in a plasma TV .
            • conan981
              • Aug 2011
              • 72
              • ITALY
              @tom66
              ehehhe sorry mate
              btw, after resoldering G1 power supply area near 370V now the TV goes on all the times!
              BUT... there is a BLACK STRIPE on the left that was not there before...
              and a nasty noise that is coming from the part i attached in photo 2 in this post. like a BZZZZ
              seems to be an endless story
              what should i check now?
              thanks to all
                Older plasmas buzz a lot, put the case on, won't be audible from 10 ft viewing distance.
                As for black strip, you need to take the bottom buffers off and inspect the flat flex drivers, may be a bad driver (=bad plasma panel) but I am aware the older ones commonly had cold joints, especially if it is intermittent, it is likely another cold solder joint
                • conan981
                  • Aug 2011
                  • 72
                  • ITALY
                  @tom66
                  thank you for your suggestion tom, but i don't understand very well what to do.
                  in attachment there are the only flat cables i found, are these that i should check or there are other ones? what should i do to check them?
                  thanks again
                    No sorry, from the bottom of the panel... you may have to take off the main board.
                    • conan981
                      • Aug 2011
                      • 72
                      • ITALY
                      just to close this adventure, i found the flat cables tom66 told me on the bottom on the tv.
                      the first one on the right (staying behind the tv) was the bad_guy.
                      i had to remove all the panels to reach the flat cable, btw i had to resolder 2 resistors on the flat cable and all went to the life again. Now tv is working perfectly
                      Really thanks to everyone here!
                        Enjoy your TV!
                        • Macedopt
                          • Feb 2013
                          • 13
                          • Portugal
                          Sorry to bring back the post, but im in serious need of help, hope i can count on you guys XD.
                          So i have the same tv thats here, but cant manage to put it working, the failure is basically the same, i can put it to work only with a mere 10 secs of blasting hot air gun (about 350 c) in the top corner of the g2 power supply, so i resoldered most of the b side of the board execpt the smd components, and cant manage to put it working, but evrytime i use the air gun it works failing if i let it complety powerd off for about 15 min.
                          Dont know what to do here do you gys can give some advice
                          thank you very much
                            Perhaps try concentrating your heat in certain areas such as electrolytic and ceramic capacitors, both of which can become temperature sensitive over time.
                            • Macedopt
                              • Feb 2013
                              • 13
                              • Portugal
                              Thanks tom66
                              So youre saing that the caps might be ruined?
                                Possibly, though ruined may be too far -- they are replaceable.
                                • Macedopt
                                  • Feb 2013
                                  • 13
                                  • Portugal
                                  Ok,
                                  just tried to heat difrent zones on the g2 board, 10 sec of air each, and no matter where i place the air it turns on, it cant be could joints because i dont stay long enough for it to melt.
                                  dont know what the hell is happening to it.
                                  any toughts guys
                                  thks
                                  • Macedopt
                                    • Feb 2013
                                    • 13
                                    • Portugal
                                    So i run another tests and it seems theyre 2 places where i can heat and tv will go on, as shown in the picture, i have resoldered pretty much evrything on those areas, and still nothing, when the hardware gets cold i cant get no image.
                                    Notice that i only heat for about 5 sec, about 350 degrees, wich i believe is not enough to melt the solder.
                                    As tom66 said it might be bad caps, but i wanna be sure, cant the transistrs or maybe thos chips be heat sensitive, in my area caps are expensive and hard to get, i know i must try because theres no guarantee in this kind of things, although just want to have more certanties.
                                    sry for my very bad english
                                    and thank yu very much for the help.
                                      It's not melting solder that you're trying to do; you're trying to make a cracked solder joint expand, which even low temperatures will do.
                                      • Macedopt
                                        • Feb 2013
                                        • 13
                                        • Portugal
                                        so you believe its cold joints il try look closer, the only thing is that no matter where i heat, on those places, it will get on.
                                        thank you
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                        • dkneyle
                                          Sony KDL-46HX850 Can't upgrade/update firmware
                                          by dkneyle
                                          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                          09-25-2024, 10:44 PM
                                          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 05:27 AM
                                          Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                                          This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                                          09-06-2024, 05:30 AM
                                          Sony VAIO VGN-TZ31WN/B TZ Specification for Upgrade or Repair
                                          This specification for the Sony VAIO VGN-TZ31WN/B can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-TZ31WN/B boardview and VGN-TZ31WN/B schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
