LG 42PX3RVA no picture
  • caspermccormack
    • Mar 2012
    • 112
    • Ireland
    Hello, I have a fault in the above tv, when i stripped it down i seen that the y-sus had a blown fuse which led me to believe that the module was also shot too. I have replaced the module and the fuse but still no picture, I have measured the AC detect and it is 4.41 stand by and 4.42 while on. All other voltages are correct coming from the PSU.
    Any Ideas????
    here is a pic of the damage on the module
  • caspermccormack
    • Mar 2012
    • 112
    • Ireland
    Re: LG 42PX3RVA no picture
    Tv has sound but no picture.
      AC detect is OK, because you have sound PSU is OK, problem is likely other fault on Y-sus, check for 200V Vs.
      • caspermccormack
        • Mar 2012
        • 112
        • Ireland
        Thanks Tom,
        187.7 on Vs , sticker says 187v,
          OK, check for shorts on Y-sustain. From either end of fuse to ground / chassis.
          • caspermccormack
            • Mar 2012
            • 112
            • Ireland
            [QUOTE=tom66;277158]OK, check for shorts on Y-sustain. From either end of fuse to ground / chassis.
            Checked that, no shorts.
              Any glow from screen in dark room?
              • caspermccormack
                • Mar 2012
                • 112
                • Ireland
                No tom, nothing at all.
                  I cannot be sure if it is the control board or the Y-sustain. You would need a scope to verify if the control board is functioning.
                  • caspermccormack
                    • Mar 2012
                    • 112
                    • Ireland
                    Got another tv today to look over and it's the same model as this one I have. I changed over the Y-Sus boards and my one is now working again. So know I know it is the Y-Sus. I have checked over for shorts on the module and found none. So what else can I look for to the board? It doesn't shut off the tv, and the sound is present.
                    Now, with the good Y-Sus installed back into the TV that I got today, I have a bad picture, lots of ghosting and speckels on the whole screen, What would be the solution to rectify this kind of fault??
                    Cheers boys!
                      See
                      https://www.badcaps.net/forum/showpo...29&postcount=7
                      In particular, adjustment of potentiometers.
                      However, problem is likely TV is in need of new control board or software flashing.
                      • caspermccormack
                        • Mar 2012
                        • 112
                        • Ireland
                        See
                        Sound Tom, nice one for your input!
                        I'll try that tomorrow. I may check over the faulty Y-Sus board for those voltages to make sure they are there. Is there any other component on the y-sus that I may be able to test and get it back working?
                        • corrize
                          A funny fuse story – Lumix LX100 II
                          by corrize
                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                          10-19-2023, 09:58 AM
                        • Tr0ll
                          by Tr0ll
                          Original T-con:
                          First replacement T-con:
                          10-07-2023, 07:48 PM
                        • JJAAMM
                          by JJAAMM
                          Problem
                          07-06-2023, 06:01 AM
                        • TR103
                          by TR103
                          - it keeps rebooting
                          01-22-2025, 04:12 PM
                        • jesterace
                          Samsung UE46ES8000 Blown fuse but no other signs of short
                          by jesterace
                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                          09-11-2024, 03:14 PM
