Gateway gtw-p50m203 power supply issue
  • freakaftr8
    • Oct 2012
    • 3743
    Hey all so I have this other set that I have been working on for a while. Originally I received it with flickering pic upon startup. This is attributed to failing surface mounted caps 25v 33mfd going south on the y sustain. Well my father in law ran this set for 2 years after I repaired it. But started it again so I used the heat gun method on the y board and pic came back.
    While its having the issue the transformers in the vs circuit are making a heck of a noise. When I find the offending cap on the y board the hiss in the power supply goes away. But this time as I powered up it blew a ceramic resistor 2.4 ohm off the vs load on the power supply. I believe it's for power sensing through a series of components and makes its way to an optocoupler. I replace the burned out rectangle ceramic power resistor and still no vs. va comes up for a split second until power supply shutdown causing a 5 blink alarm on the power supply error led. So I get va momentArly no vs. all low voltage dc supply's are there. The odd thing is that the power supply has a va and a vs ok signal from mainboard seperatly . Both are 3.3v at the time which leads me to believe the issue is mainly in the power supply. Pfc is working. I have dc to the primary's of the vs transformers but no secondary output from what I can tell with my fluke. I have tested signals from the vs on optos and the two are inline with va on on the va side. Just no vs output. I'm stumped. I have tested all switchers diodes and fets. Anyone else run into this? This is a lg built set and the unit is basically a sampo. 2003 build date. Power supply is manufactured by powerex pw-1550 and the resistor that originally blew is r24 and lg part number on the board is 3501q00004a
    Oh and I have tried disconnecting y and z from power supply too and there are no shorts between vs and ground so nothing loading down the supply.
  • Soulzink
    Samsug washing machine. Power supply DC41-00189a board issue
    by Soulzink
    I am trying to fix a samsung washinmachine power supply main board.
    I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
    Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
    The power supply board reference is the following: DC41-00189a
    I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
    04-19-2025, 06:26 AM
  • GLISIT
    by GLISIT
    01-16-2025, 02:29 PM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
    07-01-2024, 06:34 AM
  • JimBanville
    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
    by JimBanville
    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
    09-13-2023, 07:21 AM
