Samsung UN46C6500 LED TV displays vertical, thin, solid, multicolored lies/stripes
  • jlouk27
    • Aug 2012
    • Greece
    When I switch on the Samsung LED TV model UN46C6500 (or UE46C6500 in Europe) I get the whole screen filled with thin, vertical, multicolored, solid lines adjacent to each in front of the the video, see pics here :
    https://dl.dropbox.com/u/60218140/sa...pic%20no.1.jpg
    https://dl.dropbox.com/u/60218140/sa...pic%20no.2.jpg
    https://dl.dropbox.com/u/60218140/sa...pic%20no.3.jpg
    After 5-6 hours the TV video picture changes to thin, vertical, black lines like this:
    https://dl.dropbox.com/u/60218140/sa...pic%20no.4.jpg
    and finally after 1-2 hours the video is clear like it was in normal state.
    Can you please check and let me know what the problem is and how to fix it?
    Thank you.
    John.
    Re: Samsung UN46C6500 LED TV displays vertical, thin, solid, multicolored lies/stripe
    Suggest a T-con fault. Someone else on this forum has a different problem (though related), same TV (I think it was the 40" but same model otherwise), and the same diagnosis.
    • kotel studios
      Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
      by kotel studios
      Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
      In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
      08-06-2025, 02:07 AM
    • halen
      Hisense H55U7B vertical stripes
      by halen
      I have Hisense H55U7B TV with no picture, only big vertical stripes. I did several tests and I'm not sure, where is problem.
      1. Connected tcon to 12V, white, red, green, blue, black picture visible in cycle on full LCD without error
      2. Connected only left side of LCD to tcon, big stripes
      3. Connected only right side of tcon, visible normal picture on the right. Working as expected.
      Where could be problem?
      Tcon RSAG7.820.7932/ROH
      Main board RSAG7.820.8698/ROH
      Jan
      06-18-2025, 03:58 AM
    • ahoonid
      MacBook A1990 vertical stripes on external screen
      by ahoonid
      Hey everyone,
      I bought a MacBook A1990 with no screen. I bought it knowing the motherboard was defective but wasn't sure what the problem was until I received it. It actually turns on but as you see from the attachment, it has vertical stripes, on an external screen!!
      The board is neat. Not opened before for sure. Just a little dust, nothing more.
      Recovery using wifi can be opened, as can also be seen in the photo but it doesn't go all the way through after connecting it to a wifi. It downloads the initial Recovery files but never completes the rest of the...
      06-20-2025, 08:54 AM
    • Raulnn
      Lg 55LB700V with vertical stripes
      by Raulnn
      good night! I pass photos of this tv with vertical stripes. what problem could it be? panel or tcon? the tcon of this model is integrated into the panel. Let's see if they can tell me what to do to see if it can be fixed. the vertical stripes have a certain pattern, because there are some equidistant....
      04-09-2023, 04:10 PM
    • kevinman
      KD-55X9005A Vertical Stripes Right Side Mirrored Vertically At Start
      by kevinman
      Hi, TV boots with distorted image right side mirrored verticaly sometimes vertical stripes making off-on turns picture to normal and "perfect" (netflix image) that I highly doubt this is something related with t-con signal lines?? rather it looks software corruption bad mem chips voltage collapse or an intantaneous fault with fluctuating powerboard voltages?? As it happens usually when TV is cold sometimes fault comes back after a full day use should I check powerboard voltages with oscilloscope??
      12-17-2023, 06:22 AM
