LG-50PQ6000 clicks and clicks and clicks
    Re: LG-50PQ6000 clicks and clicks and clicks
    OK, that's annoying. Like the LG I fixed, it goes straight into the main microcontroller for the power supply...
    Let's try another way of finding them. All but one or two of the optos will face the same way. The two facing the opposite way may be the ones of interest. Can you find these? There's a little dot on them to identify orientation.
    • Baileybum1234
      • Sep 2012
      • 245
      These any better?
      I did a simular course about 20 years ago. Certainly worth your while mate.
      Repaired: LG50PQ6000
      • Baileybum1234
        • Sep 2012
        • 245
        Yep PC101 and PC102 have the black dot on the Primary coil side.
          OK, this is one opto, there are many more, please see which way they are facing as I mentioned in the previous post.
          • Baileybum1234
            • Sep 2012
            • 245
            Yeah you circled PC102 they have a little corner tab on the circuit drawing to indecate oreentation. PC101 is the middle one. PC101 and PC102 are the 2 out of the 6 that are the same way.
            • Baileybum1234
              • Sep 2012
              • 245
              Thought I might add and probably needless to sat TV's were tubes back then lol
                OK can you post an overall shot with a clear shot of the traces leading to those optos...
                • Baileybum1234
                  • Sep 2012
                  • 245
                  So you short the O/P on the opto isolator?
                  Hard to get a good pic mate.
                    Wrong side. We need to verify if these are the right optos as I have no experience with this PSU, please post photo as I outlined above, thanks.
                    • Baileybum1234
                      • Sep 2012
                      • 245
                      Sorry mate! Any better?
                        Sorry, meant wrong side to bridge... can you post a picture of the bottom of the PSU where the traces connect to those optos. On the live side of the PSU.
                        • Baileybum1234
                          • Sep 2012
                          • 245
                          Shorting the input to the optoisolator?? That has got me confuddled never mind if it works it works.
                            I need to see a larger scale image as on mine, the traces went all the way across the PSU. The optocoupler's input is on the LIVE side and is usually driven by some TL431's, I am trying to locate these if so I know they are the right ones. Sometimes there is just one and the other serves an important function, other times there are two.
                            • Baileybum1234
                              • Sep 2012
                              • 245
                              Ok cool will work on taking a picture tomorrow in the day light.
                              Thanks for your help with this mate. :0)
                              Jarrett
                              • Baileybum1234
                                • Sep 2012
                                • 245
                                HI mate,
                                Just managed to get a couple of snaps outside before the sun went down:
                                One of the whole board and the other or the opto-isolator outputs. I dont know if you can see IC101 and IC102 but there both 431A's??
                                Jarrett
                                  OK, they definitely look like the AC detect ones. I've highlighted where to make the bridges; keep them separate from each other.
                                  I just hope this works - as I'm not 100% that this fault applies to this PSU. Otherwise, will have to check elsewhere.
                                  • Baileybum1234
                                    • Sep 2012
                                    • 245
                                    Cool, I will look into it. So whats your theory behind this? Also have you ever done any measurements in this area with a scope or anything.
                                    I gather the opto isolator isnt stable and causing that IC to throw a wobbler? and shorting it gives a high state on the and makes it work do you think??
                                    J
                                      I did briefly scope it, and whenever my set tried to power up the AC-DET went low, and the microcontroller on the main board shut everything off, restarting the cycle. I sometimes saw a flicker from the panel but nothing more. I figure something was slightly dropping out of tolerance (perhaps the margins were set too poorly or the TL431s had failed - budm has had these fail before.) However, I have never truly located the cause of the problem as I have only had one LG with the problem.
                                      • Baileybum1234
                                        • Sep 2012
                                        • 245
                                        Thanks for your kind help with this mate. I will do a little more research before I jump in and start shorting pins. Its sounding good so far and I will keep you posted on how I do. Hope you enjoy our course.
                                        • Baileybum1234
                                          • Sep 2012
                                          • 245
                                          Well I did the mod just now and the relay clicks on/off once so thats an improvement. I will fit it into the TV tomorrow to see what happens.
                                          Just was looking for components in common to both those optoisolators and there is one electrolitic capasitor. I have lost my DVM so cant test it grrrrr.
                                          • Flaku_34
                                            Acer Nitro XV273 and Predator XB273, look inside and disassembly guide.
                                            by Flaku_34
                                            Introduction:
                                            Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...
                                            04-18-2024, 12:47 PM
                                          • Sisko
                                            Onkyo-593 No power and now clicking sound
                                            by Sisko
                                            Hi all!!
                                            Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                            10-03-2025, 02:18 PM
                                          • harp
                                            question/caution note to usage of linear psu
                                            by harp
                                            I have UNI-T UTP3315TFL (2025 model) and just want to measure some zenner diodes directly with it. Set it to 12v and 7mA and connect BZX85C9V1 to it... shown on display 8.91v at 7mA... that seem fine to me. But, I guess I have in box a larger zener, let set it up to 16v, same current. Relay inside clicking to bigger range over 15v. When I test the sameone zenner accross probe, it clicks back to lower range, but displayed about 0v. The zenner was samehow killed by switching winding on 7mA limit... It was a 1W zenner, and can take up much higher voltage and current, so what is hapened realy, am...
                                            10-15-2025, 03:54 AM
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • dansity
                                            Denon AVR 1912 no sound
                                            by dansity
                                            As a foreword I'm relatively novice with component level audio gear repair. My amplifier stopped producing sound and I currently have no funds to buy a new one so I need any help to repair it. I know "no sound" is one of the most common problem but there were other symptoms so some of you seasoned repairman might able to pinpoint the stuff I have to check. I did download the service manual from manualslib the "no sound checklist" is a bit intimidating.
                                            So i bought it working. First symptom: speaker protection relays on the audio board were clicking...
                                            05-06-2024, 10:16 AM
