sony bravia
  • mariovasquez
    • Sep 2012
    • usa
    sony bravia
    I have asony bravia 37", dont power up, check caps and they look ok., any sugestion
    mario
    • Jul 2011
    • 6070
    Re: sony bravia
    Can you Please post some photo of all the board front and back in this set
    This would be very helpful
    • drpj23
      • May 2012
      • 528
      Re: sony bravia
      Is there an error code or does it have at least a standby light/ power on light?
      • mijatovic86
        • May 2012
        • 17
        • Sebia
        Re: sony bravia
        Post photos, post exact numbers of the boards, Sony model etc...
        and post LED behavior Green led lights up or not, red led blinks how many times...
        • JUCaESAl
          Sony bravia KD-65AF9
          by JUCaESAl
          Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
          Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
          10-20-2025, 04:03 AM
        • PopsCaps
          Sony Bravia KDL-40V2500 that will not power on
          by PopsCaps
          I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
          I do not hear any sound and I cannot see any backlight.
          I have tried disconnecting every cable on each board one at a time to see if anything changes.
          The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
          My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
          03-25-2025, 11:23 AM
        • alegatorul
          sony bravia kdl-43w756c, no power, no sound
          by alegatorul
          the charger brick has 19,2-19,3 vcc
          changed the inverter board same result.
          where should i start?
          cheers
          11-15-2025, 10:00 AM
        • justin35
          Sony bravia kdl-43w755c - boot loop
          by justin35
          i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
          from what i read online it looks to be an emmc issue…
          i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
          i took out the board and say an samsung 16gb emmc
          i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
          i could try to put one instead of the 16gb one, but will it work?
          where do i get the software from?
          any help will be much appreciated!...
          03-06-2024, 12:26 PM
          Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
          Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
          10-16-2024, 05:15 AM
