overlapping pictures on 46" lcd tv
  • daddydave
    • Sep 2012
    • 5
    • canada
    Hi there,
    I have a 46" samsung lcd tv that started having pictures issues about a few weeks ago. at first it would take about 15-20 min for the pictures to clear, now it's bad all the time, overlapping pictures. hope someone can tell me how to fix it. thanks in advance for any help!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: overlapping pictures on 46" lcd tv
    If you gently flex the sides and top/bottom of the TV, does that fix the picture? If yes, you might have bad tab bonds.
    --- begin sig file ---
    --- end sig file ---
    • daddydave
      • Sep 2012
      • 5
      • canada
      Hi, when i press the sides the pictures gets worse. the left side is worse, the right side looks ok. it's strange, is i'm typing this and i looked at the tv, the picture is seddenly perfet after being bad the past few days. i don't know if got anyhting to do with me pressing the sides, but when i was pressing then it was getting worse and after a few min, it suddenly looks fine. here are some new picture i took a few minutes ago.
      regards,
      • retiredcaps
        • Apr 2010
        • 9271
        Search for "tab bond bump ons" in your favourite search engine or youtube. Some people report it fixes the problem. Others use tape, weather stripping, etc. The whole idea is to put pressure on the tab bond so it makes a connection to the lcd panel.
        Report back if it fixes it for you.
        I have a Toshiba 46 lcd with the same problem and I just need to find a couple of days on uninterrupted time to look at it.
        • obelix24
          A1534 820-00045 - USB-C not working both sides
          by obelix24
          Hi All,
          I just got one Macbook 12" that was not powering on. I found out that the battery was flat on right side so I charged it little bit with power supply and the MacBook turns on.
          Problems that I have when I connect everything I can see for second apple logo and it it dims down, then there is apple logo with progress bar also only for second and then dims down. I found that issue is with trackpad (probably keyboard part) as when I disconnect keyboard from trackpad MacBook boots up normally. I took off the black cover on keyboard I was expecting some water damage...
          11-07-2023, 07:44 AM
        • bohaboha
          Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
          by bohaboha
          Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
          anyhow i couldn't t read anything else
          the backlight is on strong and the screen does not get dark or very dark but no pictures
          the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
          01-02-2025, 08:04 PM
        • valvashon
          LG 55UH6150- trouble powering up, then half lit screen (pictures!)
          by valvashon
          The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
          Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
          11-24-2024, 12:08 PM
        • Flaku_34
          Acer Nitro XV273 and Predator XB273, look inside and disassembly guide.
          by Flaku_34
          Introduction:
          Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...
          04-18-2024, 12:47 PM
        • howardc64
          by howardc64
          Today, 05:17 PM
