Jw60
  • JW60
    • Sep 2012
    • usa
    Jw60
    I have a LG 50pc3d plasma tv that is doing wierd thing when you power up after tv has been off over night or long periods of time.When you power the tv up it cycle on &off for about 15 mins. then stay on .It has a mind of its own .i can't cut off with power switch during this cycle .Ive got to cut breaker off in fuse box since the tv power outlet is on wall an can't reach it.Do I replace the power board or the caps.Seems that power boards are out of stock for this model. THE TV IS FREAKING ME OUT HELP!!!!
    JW60
  • drpj23
    • May 2012
    • 528
    Re: Jw60
    So after this 15 min cycle it will work normally i.e. cut on and off without any probs?
    Is it about 15 min everytime?
    So we can safely assume it is within the main or the power supply. But to be sure I would unplug the Z and Y sustain boards to make sure it's not faulting the power supply (though very unlikely since it is restarting)
    Open the tv and check for bad caps (bulging) especially in the top left.
    Do you see about 5 3300 uf 10v caps?
    And future reference, it might be wiser to include the model of the the tv and slight descrip of error in the title so those who have experience with these sets can help you (or at least quicker)
    Oh and if you can, please include pics.
    • JW60
      • Sep 2012
      • usa
      Re: Jw60
      Thanks for info i will open it up and will enclude pictures. It doesn't do it everytime in fact it's worked fine all weekend until tonite.it started again going from red to green. I cut off breaker an killed power .reset breaker hit the power button it cycled about 4 times an tv powered up.an stayed on.i the model# plasma 50pc3d
      thanks jw60
      • JW60
        • Sep 2012
        • usa
        Re: Jw60 LG PLASMA MODEL 50PC3D POWERING ON&OFF
        Originally posted by jw60
        i have a lg 50pc3d plasma tv that is doing wierd thing when you power up after tv has been off over night or long periods of time.when you power the tv up it cycle on &off for about 15 mins. Then stay on .it has a mind of its own .i can't cut off with power switch during this cycle .ive got to cut breaker off in fuse box since the tv power outlet is on wall an can't reach it.do i replace the power board or the caps.seems that power boards are out of stock for this model. The tv is freaking me out help!!!!
        Jw60
        thanks
        • meraklinetx
          Asus Z97-a power cycle, no boot no cpu voltage
          by meraklinetx
          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
          05-10-2023, 06:08 AM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
          03-31-2024, 02:12 PM
