Lg plasma tv no video has sound
  • anthonyngan
    • Aug 2012
    • 23
    Re: Lg plasma tv no video has sound
    Hi guys here's an update on what's going on with my LG plasma TV.
    I tried to resolder new ipms on my original y sustain board. however I still had a short on this particular board; Vs to ground short. I had a hard time finding where that short was coming from. So I decided to order a new y sustain board.
    I received it today. I Connected the board but I still have to same problem. I only get voltage out of the power supply board when the p2 connector on the y sus is unplugged see picture. So I tested this new board but But there is no short at all.
    So I guess the problem is not coming from my y sustain board. I also tried to disconnect the buffer boards from the y sus But it makes no difference. I'm really at loss here. Can something else have an influence? I'm starting to wonder if there is a problem with the control boards. There is this small connector P1 which I didn't try to disconnect him but I'm afraid that this might cause further problems. Any help would be greatly appreciated.
    Power board and z sus:
    • anthonyngan
      • Aug 2012
      • 23
      New y sustain board
      • anthonyngan
        • Aug 2012
        • 23
        P2 the one that needs to be disconnected in order to get dc voltage out of the PS.
        • anthonyngan
          • Aug 2012
          • 23
          Buffer, y and control boards.
            Have you tried without Z-sustain connected?
            • anthonyngan
              • Aug 2012
              • 23
              Hi Tom, thanks again for your help.
              Yes I tried that already. The only way to get for voltage out of the power supply is to disconnect this P2 connector.
              • anthonyngan
                • Aug 2012
                • 23
                Is it possible that there something wrong with the power supply? As if something goes wrong when voltage is suck out of it. Maybe bad capacitors?
                  Well, it sounds like both of your boards have a short circuit. You could try with a 230V light bulb across Vs to see if you can get it to drive one of those, if it can't, it could be the PSU at fault.
                  • anthonyngan
                    • Aug 2012
                    • 23
                    Hi again I would really appreciate your help. I don't want to give up on this puzzle.
                    I didn't try to do the bulb tests which you were suggesting. Since there was a VS to ground short on the power supply board I decided to buy another one from this online shop LCD parts from UK. I Just plugged it in. I really thought that it could solve the case this time.
                    Unfortunately i have the same problem again...
                    No Vs va or vy voltage coming out of the power supply board when P2 connector on y sustain board is connected.
                    I even unplugged every connector that was going out from the power supply board Except for that p2 connector. There is no difference I only get voltage out of the supply board when this connector is unplugged.
                    I tried to isolate the y sustain board by unplugging to buffer boards but it didn't make any difference.
                    I could use some live help (Skype, FaceTime ...)
                    Thanks!
                    P.S. I won't give up !
                    • anthonyngan
                      • Aug 2012
                      • 23
                      Hi again,
                      I'm starting to believe that the y sustain board I received is defective. However there is no short to ground on that board. This question might seem silly But is it possible that the board is defective without having any short to grounds?
                        Yes it is quite possible, we have seen it several times before.
                        It could be one of the FETs in the IPM is short, and only when the other part of the IPM tries to turn on, does it go wrong.
                        You could experiment with the control connector disconnected - the flex rigid cable going to the control board in the centre of the screen. That way the FET may be off, but the Y-sus is still powered. Then see if Vsus is still zero.
                        • anthonyngan
                          • Aug 2012
                          • 23
                          By the way I just found this very nice article about power supply boards of plasma TV
                          http://www.bestelectronicarticles.co...eshooting.html
                          It helped me understand that the problem is really Coming from my Y sustain board.
                          Just wanted to share the link in case it might help somebody
                          • anthonyngan
                            • Aug 2012
                            • 23
                            I'm very happy to say that I'm making some progress here!
                            Thanks to the help of Tom and all other posts I found here I was able to get an image out of my TV! The image is not perfect yet a lot of flashing and flickering but and I'm positive I'll find the help I need to resolve the problem.
                            Here's a quick recap of what I did.
                            Got this TV for free LG plasma 42 inches mu-42pz15.
                            It's a commercial model and I really wanted to fix that TV instead of letting it go to the dump.
                            I found that y sustain board was at fault cause every time I unplugged the connector to that board I would get voltage out of the power supply.
                            I ordered IPMs from China, Replace them on the board but it didn't work. So I ordered a new board. Unfortunately the board was defective. So I thought that the power supply was at fault so I ordered a new power supply. It didn't solve my problem so at last I replaced again the IPM on the my y sus board and it worked!
                            Now I think I'm facing the last obstacle to successfully repair the TV.
                            The image is flickering and flashing I'm going to try to adjust voltage but I'm really not sure what to do with this problem.
                            Again any suggestions is welcome!
                              Try without upper or lower buffers installed (one removed.)
                              Could also be dodgy Vs.
                              Or bad control board.
                              http://www.youtube.com/watch?v=rEVs6...feature=relmfu
                              http://www.youtube.com/watch?v=UAzsasx8od8
                              • anthonyngan
                                • Aug 2012
                                • 23
                                Success!
                                Turned out a connector on that the main was not properly connected.
                                Tv is now working and the whole family is enjoying!
                                Thanks for the help.
                                  Glad you fixed it!
                                  • santoshpradhan
                                    mobile and tv
                                    • May 2013
                                    • india
                                    #37
                                    first of thanks ,
                                    i had a problem with lg flat crt tv comes beeps sound during power no sound and no display
                                    sir i had lg tv ra21fa26v with power on problem with long beeps please suggest solution
                                    • soeren
                                      A2442 - No sound over internal speakers and no video playback
                                      by soeren
                                      I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
                                      All happened after the battery ran out of power overall several days when I was on vacation.
                                      I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
                                      07-26-2024, 01:24 AM
                                    • FrancescoV
                                      Onkyo HT-R390 no sound output, video output ok
                                      by FrancescoV
                                      Good morning everyone,
                                      I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                      The firmware reported is the following:
                                      M:1.00/11107BLP
                                      D:?.??/????????
                                      O:1.00/11107AL
                                      The DSP firmware given the question marks seems corrupt.
                                      On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                      05-11-2025, 02:59 AM
                                      HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                      This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                      09-12-2024, 02:00 PM
                                    • Max514
                                      Samsung UN55H8000 sound but no backlight no video
                                      by Max514
                                      Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
                                      The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
                                      I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
                                      • Unplugging the main board cable at the power supply >>> backlights came on.
                                      • BLU_ON signal from the
                                      04-14-2022, 10:34 AM
                                    • LEECH666
                                      Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                      by LEECH666
                                      Good day ladies and gentleman!
                                      I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                      This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                      I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                      01-19-2024, 05:46 PM
