Samsung le23r88bd (r)
  • Berts
    • Aug 2012
    • 55
    • Scotland
    I have a SAMSUNG LE23R88BD (R) TV.
    The unit powers on but the display is black. No back-light or picture.
    I have disassembled the unit but can see no signs of bloated capacitors.
    just wondering what my next steps should be?
    Replace inverter?
    Berts
    Re: Samsung le23r88bd (r)
    See if you can get sound from an external source.
    • Berts
      • Aug 2012
      • 55
      • Scotland
      Hi, thanks for replying.
      I have tried an external audio source to the TV and have no output, however the standby light comes on and flashes with the remote control, so I would assume power is getting there somewhere.
      Any more thoughts?
      Berts
        Have you tried pressing the SOURCE button to change input?
        • Berts
          • Aug 2012
          • 55
          • Scotland
          Yes pressed the source button a few times just to cycle it. Will try again to make sure.
          • Berts
            • Aug 2012
            • 55
            • Scotland
            Yes definable cannot get audio, any ideas as what to check next?
            • Berts
              • Aug 2012
              • 55
              • Scotland
              I have noticed a whining sound from the power board.
              It starts low and increases, last about 3 seconds then repeats over and over.
              Any ideas?
                Sounds possibly like an MCU starting up and failing? Does the power board show any signs of having the caps replaced - are they Samwhas or other?
                • selldoor
                  Slow Learner
                  • 7870
                  Seem to be working blind here - can you post some pictures?
                  please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
                  Examples of what is needed
                  https://www.badcaps.net/forum/attach...1&d=1290283049
                  https://www.badcaps.net/forum/attach...7&d=1280167246
                  • Berts
                    • Aug 2012
                    • 55
                    • Scotland
                    Hey, thanks for helping. Photos are attached, The large Cap on the power board looks a bit swollen, but I don't know if that is what they normally look like?
                    Also the Blue rectangular component on the power board has slight burn marks on the back, looks like it may have been repaired?
                    • selldoor
                      Slow Learner
                      • 7870
                      ^^^^attached to what?
                      • Berts
                        • Aug 2012
                        • 55
                        • Scotland
                        Sorry, I thought they had attached.
                        Here you go....
                        • Berts
                          • Aug 2012
                          • 55
                          • Scotland
                          I have drawn a white arrow on the power board to the components that look suspect to me. Thanks again for any help.
                          • selldoor
                            Slow Learner
                            • 7870
                            Sometimes the Big Cap plastic lid looks a bit rounded if that is what you mean? we could tell better with a side view. The blue box is a capacitor but dont often fail.
                            On the inverter board - pic 5 there are 3 fuses (at least) can you check them using ohms 20 on your meter post results like Inv Bd F1 x ohms and so on.
                            Have you checked the red fuse on the power supply
                            • Berts
                              • Aug 2012
                              • 55
                              • Scotland
                              Hi would it be too much trouble to ask you to point out the location of the fuses you suggest that I should test? thanks and sorry to be a pain, am quite new to TV's
                              • selldoor
                                Slow Learner
                                • 7870
                                Tcon attached- there may be more cant see for flash and item in dots
                                not sure what that is but just test for continuity.
                                Red fuse on main board is a red rectangular fuse below the label that says
                                5WO.39(ohms)j
                                hint:
                                Suggest you type in fuse ( Or whatever component) to google and select images - you will get to see every fuse imaginable. Capacitors are good too from pinhead to the ones on overhead powerlines.
                                • Berts
                                  • Aug 2012
                                  • 55
                                  • Scotland
                                  Thanks mate, will post back how I get on. Really appreciate you time.
                                  • Berts
                                    • Aug 2012
                                    • 55
                                    • Scotland
                                    Hi, all the fuses are good. The more I look into this the more I believe that it is a bad Cap on the power board. I have read another thread and a guy with exactly the same problem replaced the big blue cap and had success this would also concur with the heat damage to the board which is on one of the legs of that Cap.
                                    My problem is now I am in the UK and the only place I can see where to get a similar Cap is here
                                    http://www.digikey.co.uk/scripts/DKS...16859614659808
                                    Its not the exact one but I am told it should work.
                                    The postage from America is £12 and I was wondering if anyone knew of a place in the Uk selling the same component?
                                    Thanks again Selldoor for all your help, hopefully this works.
                                      Try Farnell.
                                      • Berts
                                        • Aug 2012
                                        • 55
                                        • Scotland
                                        Thanks Tom
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
