Ps-50p96fd
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by AkuankaHi everyone,
I'm troubleshooting a power supply issue with a Sony SLV-E780 VCR. The device clicks repeatedly but doesn't power up completely. I've already replaced five capacitors, but the problem persists.
Here's a video link https://photos.app.goo.gl/3Xki6yvCLn67gLX78 showcasing the sound. Based on your experience, could this be due to a transformer, diode, or another component? Any guidance on what to test or replace next would be greatly appreciated.
Thanks in advance for your help! -
by son_goku1976Hi all, I have a problem with the following TV: I'm sure the problem is with the power supply..... in fact I tried a power supply that they lent me bn44-00473b instead of the original one bn44-00473a and the TV works normally .. .
The defect found is that the LED emits 5 double flashes and does not turn on.... can you tell me which section to check or better, what tests to do? Thank you - Loading...
