Samsung LE40856S1M Main PCB Board problem!
  • HerculesDK
    • Jul 2012
    • 21
    • Denmark
    Hi guys,
    I have a Samsung LE40A856S1M TV, which (I think) has a short circuit somewhere. I believe it is due to a HDMI cable that was on and not inserted properly in the HDMI port from my PS3. This caused the malfunction of the TV set. Now I have 2 choices I guess:
    1) Fix the current PCB mainboard AV Signal board or
    2) Buy a new part for it.
    If I have to buy a new mainboard then I want to buy the one from the Samsung LE40A866S1M TV as it has a Mpeg4 tuner. But I cant seem to find it anywhere?
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • jb_Bak
    by jb_Bak
    CN6401
    Pin 01 NC
    Pin 02 NC
    Pin 03 "BL_ON": 0V
    Pin 04 "N/C"
    Pin 05 "STBY 3.3V": 3.5V
    Pin 06 "GND": N/C
    Pin 07 "AC_OFF"...
    09-27-2021, 04:52 PM
  • JDC
    by JDC
    ONN 100012588
    Long answer:
    07-15-2022, 07:39 AM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • cheeky2
    by cheeky2
    05-25-2024, 03:27 AM
