Re: Toshiba TV not powering on?
Started a separate thread here:
https://www.badcaps.net/forum/showth...110#post514110
One last thing - anyone know where to unplug the seine board?Leave a comment:
This is an old thread, but since I just acquired a Toshiba 37LX96 that won't turn on, but you can hear the relays on the power board cycling, I'd thought I'd resurrect it.
I have the exact same power board, and I replaced all three ICs normally suspect. strz4479, strw6765, and srx2039. Now I should say before I did this, the tv wouldn't come on, but would flash three yellow lights. After I replaced these ICs, no yellow lights, and now the relays click on off on off. The caps visually look alright.
I will test the caps properly. My layout of boards is the same, should I try to find the connector to the seine board and unplug it?Leave a comment:
Update:
I have ordered STR-W6765, cost me $3.28 w/free shipping from China.
Should arrive in 2-3 wks, (sigh).
Very hesitant to order, as I am unsure if this is the SOLE problem, not sure how to check or diagnose, but...
...I will post details of the repair...ie fixed or not.Leave a comment:
Same TV, same problem. Bigger screen, but same boards.
(refer to previous pics, all are the same equipment as mine)
The story thus far:
I received this tv, for free, from CL. Sweet find!
The original owner claimed that it wasn't working, was flashing three green lights (SEINE problem). I brought the tv home, plugged it in, pushed the dvd eject button (heard the drive clicking)...and suddenly it worked! Sweet score!
Connected the ps3 with an hdmi, and was good to go...or so i thought.
...then several weeks later, a transformer blew outside my neighborhood (not sure if this is important). I turned the TV on, and it worked, but when I switched it over to the hdmi input, it turned off and hasn't turned on since.
No lights, no power, nothing. Nada.
Plug it in, and the "clicks are heard" in the switch relays. Hold the power button for 5 seconds, and again "clicks" are heard. Opened the switch relay covers to visually confirm this.
Discovered this thread, and eagerly read through it all...hoping someone discovered the magical fix but, to my dismay, most people tend to find buying a new tv easier than fixing this one. It seems a new TV is also in my future.
I will post pics of the PSU, front and back. I notice burn spots (?) at several places across the board...
Would love some advice, suggestions, questions, or ideas.
Thanks in advance!
I hate chuckin TV's in the trash...Leave a comment:
possible Q880 (strw6765)...? i have one with same problemLeave a comment:
"CUSTOMER COMPLAINS OF UNIT NOT POWERING ON AND 'TICK' SOUND HEARD"
"TECH CONFIRMS COMPLAINTS"
"POWER CYCLED UNIT AND CHECKED VOLTAGES OF COMPONENTS SUSPECT TO FAILURE"
"CAPACITORS SHOWING GOOD VOLTAGE; NO FAILED CAPS"
"REPLACED POWER AND BOARD COMPONENTS SUSPECT OF FAILURE"
"UNIT DOES NOT POWER ON"
"DISCONNECTED 'SEINE' BOARD OF UNIT; UNIT POWERS ON WITH LIMITED FUNCTIONALITY"
"RECONNECTED 'SEINE BOARD' UNIT IS FULLY FUNCTIONAL"
"UNIT IS REPAIRED"
"Leave a comment:
So Senatov, did you fix the tv or not? I had a similar Toshiba with the same problem. these power boards are hard to find to buy.Leave a comment:
For $20 I can fix both of these parts myself. I just ordered them on Amazon. I hope it fixes it. I want to thank everyone for the outstanding help I have received. I was at the store a few days ago with the money in my pocket, ready to buy a new TV, but I thought, "I might be able to fix it." Thanks!Leave a comment:
I found the Q860, but I am not sure what it refers to. Here is a picture:
https://www.badcaps.net/forum/attach...1&d=1344343044
UPDATE: Is it the black thing inside the metal thing?Leave a comment:
Yes, it is the black thing clipped to the heat sink. Q860 and Q880 are both switching regulator control ICs. Overload protection is just one of the incorporated features of most switching regulator ICs.Leave a comment:
The generic part # for Q880 is STRW6765. When I replace that, I also replace Q860, part # STRZ4479, as they most often seem to fail together, and they are not too expensive. I have had to replace these on numerous units of this model, as the power board has not been available for several years.
UPDATE: Is it the black thing inside the metal thing?Last edited by Senatov; 08-07-2012, 06:40 AM.Leave a comment:
You mean the black thing in the picture? Why is this preventing the TV from turning on?Leave a comment:
Yes that is STR-W6765.
On the set i was working on i noticed alot of heat or burning on the solder side of the board at Q880.Leave a comment:
The document that you provided mentions that this is an overload protector. Does this mean that the problem is over voltage? If it is not, what is wrong with that component?Leave a comment:
Just to be clear, the thing that needs to be replaced is this:
https://www.badcaps.net/forum/attach...1&d=1344341111Leave a comment:
Hello Everyone!
I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died....06-28-2025, 02:57 PM -
This specification for the Toshiba Satellite Pro C660-1NQ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C660-1NQ boardview and C660-1NQ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:27 AM
This specification for the Toshiba Satellite L655-1DJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L655-1DJ boardview and L655-1DJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
This specification for the Toshiba Satellite L655-19C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L655-19C boardview and L655-19C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
This specification for the Toshiba Satellite L635-10K Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L635-10K boardview and L635-10K schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
- Loading...
