Toshiba TV not powering on?
  • Senatov
    replied
    Re: Toshiba TV not powering on?
    What is Q880 and why does it prevent the TV from turning on?
  • randtek
    replied
    The generic part # for Q880 is STRW6765. When I replace that, I also replace Q860, part # STRZ4479, as they most often seem to fail together, and they are not too expensive. I have had to replace these on numerous units of this model, as the power board has not been available for several years.
  • selldoor
    replied
    No it doesnt refer to the heatsink - It is a component that is under the lip of the heatsink
    attached to the vertical wall of the heatsink and soldered to the board. Alexanna has said it probably has 5 pins.
    You will need to remove the board from the frame then remove the heatsink and the component to check the part number.
    I dont think the seine board problem has ever been resolved.
  • Senatov
    replied
    Underneath that heat sink that I showed a picture of, and to the left ever so slightly, I found Q880 with no "a" at the end. It probably still refers to the silver heat sink. What could be wrong with it that could prevent the TV from turning on?
  • Senatov
    replied
    Here is a picture of it:
    https://www.badcaps.net/forum/attach...1&d=1344298458
    This sounds exactly like what was said in that other thread
    (https://www.badcaps.net/forum/showth...213#post212213)
    Same TV, Same Symptoms, Same Problem. I think we have found the problem. How do I fix this? What needs fixing? Where do I get the parts?
    P.S. We are talking about the Heat Sink, correct?
  • Senatov
    replied
    I found "Q880A." It appears that this is referring to a heat sink. Also, how did you disconnect the SEINE board?
  • Senatov
    replied
    Originally posted by alexanna
    It is on one of the four corners of the board,I think it is a 5 pin thru hole attatched to a heat sink
    Can you circle it on one of these pictures? I have been hunched over the TV for 30 minutes with a magnifying glass and a light trying to find it. All I can find is things that say Q8XXX, no Q880.
  • alexanna
    replied
  • Senatov
    replied
    look at Q880 closely for dammage if it fails realy flacky voltages will be noticed.
    https://www.badcaps.net/forum/attach...5&d=1321796453
    It's on the U801 power board
    I am having a problem locating the "Q880" on the actual TV, could you help?
  • Senatov
    replied
    You have the same TV and problem as me.
  • alexanna
    replied
  • ben7
    replied
    Originally posted by Senatov
    You can't. I tried. The metal is all 1 piece and it runs under all the boards, and is welded to the frame of the TV. No can do.
    There has to be, maybe tom66 will know.
  • Senatov
    replied
    Originally posted by ben7
    Waa?! Theres gotta be a way to get under there!
  • ben7
    replied
    Unfortunately, I cannot get to what is under the question mark since the metal panel is all 1 piece and is welded to the wrest of the frame. Also the blue circle connector does not come off.
  • Senatov
    replied
    LOL!
    I didn't
    Thats like the third time today xD
    here it is:
  • ben7
    replied
    Did you attach an image? I do not see it. Sorry.
    LOL!
    I didn't
    here it is:
  • Senatov
    replied
    Ok, so, did you try un-plugging the connectors in the blue circle below?
    And, what is under the red question mark? I think its the inverter, and we should try to un-plug it to see if it is at fault.
  • ben7
    replied
    Let me try again...
    Okay, here are some pictures with the metal thing off. Sorry if it is not zoomed in enough. It is hard to capture the whole thing and get the details.
    Here is it with the metal thing off: https://www.badcaps.net/forum/attach...1&d=1344291224
    Here is that plug you asked about: https://www.badcaps.net/forum/attach...1&d=1344291224
    UPDATE: For some reason my computer was shortening the link and adding "..."
  • Senatov
    replied
    Let me try again...
  • ben7
    replied
    That's weird. It opens on my computer.
    Attach them to your post using the manage attachments option.
  • serious_electron
    Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
    by serious_electron
    Hello Everyone!
    I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
    06-28-2025, 02:57 PM
    09-06-2024, 05:27 AM
    09-06-2024, 05:59 AM
