Sony KV-34HS420, blinking standby light
  • Freezer
    • Jun 2010
    • 124
    I have a Sony KV-34HS420 with blinking standby light. This TV is a widescreen CRT with full 1080 resolution and HDMI input. I personally think the image is as good as any LCD or plasma. The problem is the set won't turn on. When you apply power the standby light on the front starts flashing. Most of the time it flashes 6 times, but sometimes it flashes 7, and one time it flashed 4.
    I know this era Sony TVs has a systemic problem with two ICs on the DZ board. The replacement part is the MCZ3001DB, easy to find on eBay. These chips are marked "A" in the attached picture. Sony recommends replacing two fusible resistors (B) and two capacitors (C) at the same time. I have an ESR meter and my caps tested fine, so I did not replace them. But I did replace the fusible resistors (part number 120293361 - .1ohm 1/2watt fusible resistor). The final part I replaced is IC5004, a STV9379A. The service manual recommends replacing this part for 4 blink codes. And since I got a 4 blink code once I figured might as well do the work while I'm in there.
    I'm by no means an expert when it comes to working on CRT TVs. I know they can have very high voltage with the real potential to injure or kill. The tube is supposed to self discharge when turned off and unplugged. I left the TV in this state for days to ensure it's discharged - but even still I was very careful. To remove the DZ board, first remove all the screws. The tricky one is located near the front of the TV. It's hard to see and access, so be patient. Next, the clips connecting the DZ and A boards need to be removed. They swing up like a draw bridge (hinged on the A board side) and require a decent amount of force. Finally, remove the wires from the DZ board. This will ALMOST free the SZ board. The problem is the FBT wire to the anode cup on the tube itself. Some people disconnect this, but I've heard you're just as likely to damage it, so I left it connected and worked on the board while it's still connected to the TV. Just kind of prop the board up against the TV.
    Replacing all the parts was relatively straight forward, at least if you have a lot of experience with a soldering iron. I'm convinced one or both of the MCZ3001DBs were bad but there's no way to test. My guess is the STV9379A was good and didn't need to be replaced, but the part was only $2. As for the fusible resistors, one of them was definitely bad. I don't know the official way to test a fusible resistor, but I just used the resistance setting on my multimeter. The two new ones measured about .3 ohms. One of the old ones measured at .3 ohms, but the other measured at something like 10 Mohms. So I'm assuming that means it was bad.
    I got all five components replaced, put the board back in, and (with fingers crossed) turned it on. Success! It's alive again.
    I wish I could say that was the end of the store, but alas there is a minor problem with the image. About 1/3 of the way down the screen there is a single horizontal green line, red line, and blue line (each about 1/4" apart). These lines run the full width of the screen regardless of input of video settings. The service manual has several pages with instructions on how to properly dress the cables to prevent image distortion. It also has a section on calibrating the TV. I need to go through both of these. But first I wanted to post the problem here and see if anyone else has run into an image problem like this. Any ideas what could be causing these lines?
  • Freezer
    • Jun 2010
    • 124
    Re: Sony KV-34HS420, blinking standby light
    I think I can answer my own question here. If you read the service manual for this (or other similar Sony CRT TVs) they have 3 areas to check; cable dressing, physical calibration, and electrical calibration.
    1. Cable Dressing
    Since CRTs generate magnetic fields and have really high voltages in them, the placement of certain wires inside the set can negatively impact the image. To remove the board and solder in the new parts you have to disconnect some wires and move others. So make sure to follow the cable dressing section to get all the wires back into place.
    2. Physical Calibration
    This step involves a lot of tweaking of the "gun" alignment. I think these steps must be followed if you replace the tube itself, or any of the boards on the back of the tube that control the "guns." Since I didn't do this, I think it's safe to skip this.
    3. Electrical Calibration
    This final step is done with the TV turned on and using the remote control to navigate the hidden service menu. There are easily 100 or more settings than can be controlled in here, everything from pincushion to colors levels to HDMI version.
    The electrical calibration is where you need to go to fine tune the TV after replacing the chips. Figuring out how to navigate using the remote, change values, and SAVING the new values takes time. I only wish I knew what I was doing first. My first idea was to completely wipe the flash RAM in the TV thus restoring factory defaults. Big mistake, the factory defaults don't even know what model of TV this is. Fortunately the service manual includes the defaults for this model TV. So now it's a question of can I successfully program these 100 or more settings and restore them to what they should be. Then change the one or two values that move the position of those lines? By clearing the memory first instead of RTFM I created a ton of work for myself.
    • brithepi2k
      Sony KD-65XE8596 no standby light
      by brithepi2k
      I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
      cheers...
      09-06-2025, 02:22 PM
    • YasaCh
      Sony kdl 40p5500 red light keeps blinking 3 times
      by YasaCh
      Hello...
      my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
      i opened the back cover no sign of damage on the powery suply or motherboard
      when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
      another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
      07-07-2025, 11:53 AM
    • mecha1166
      QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
      by mecha1166
      I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
      03-28-2024, 08:31 AM
    • androripara
      Sony Bravia 55HX820 - 4 times blinking red standby led
      by androripara
      i am trying to repair a Sony KDL-55HX820 led TV which is throwing error code 4 (standby led flashing four times).
      I followed the troubleshooting flowchart at page 69, and between pin1 and pin7 of CN6002 i am reading 1.91V so i guess i can rule out the B Board as the culprit.
      Before ordering new G* Boards (by the way, should i change both? it is not specified in the manual) i wanted to try and do more advanced troubleshooting since i've read in other threads people resolving their problems on the 46/55 HX 820/823/825 models by replacing the Samsung led...
      10-19-2023, 05:16 AM
    • ChristianBr01
      LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
      by ChristianBr01
      I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
      The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
      What I already found is that the 12.8V are not an the connector to the main board connector to the power...
      04-23-2025, 01:48 AM
