vizio VW42L voltage too high help
  • marlboroa
    • Jul 2012
    • 59
    Re: vizio VW42L voltage too high help
    Im going to order a few new replacements for it. It worked fine yesterday and today it will go for 5-10 minutes then loose picture. I still have sound and the backlight just no pic. If i turn it off then back on i can get the pic for about 10 seconds. seems like the longer its turned off and can cool down, the longer it will stay on for. It was off all last night and worked for about an hour today before acting up. now if its turned off for about 20 minutes it will work for 5-10 minutes.
    • marlboroa
      • Jul 2012
      • 59
      Its this the correct one for U7? mines a AMC1117
      http://www.digikey.com/product-detai...98-1-ND/705738
      or if someone can pick it out of this list that would be great
      http://www.mouser.com/Semiconductors...ulator&FS=True
      • marlboroa
        • Jul 2012
        • 59
        anyone??? I dont want to order the wrong part.
          That part is fine.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • DynaxSC
            Extreme High Current & Low Voltage Short Killer ??
            by DynaxSC
            Hi Folks
            I'm looking for a extreme high current short killer solution for a reasonable cost.
            I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
            After taking off the socket, the shorts dissappear again.
            The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
            10-15-2024, 10:13 AM
          • SoporteHR
            LG 42PQ30R TV power supply does not work high voltage. (Liteon PS-7411-1-LF Rev. 2.1
            by SoporteHR
            Greetings to all, I hope you are well.
            I consult you because I have a problem with this power source.
            The TV when it is connected to the electrical power turns on the blue light but does not give an image. the source is heard a hum.
            When I disconnect the power from the TV plates and power it up by itself, the hum goes away.
            I have the STB voltages of 5vdc. The microcontroller is powered with said voltage and the main board LED lights up.
            but not the 12v or 17v ones, nor the 300vdc high voltage voltages, nor the VS or VA....
            06-20-2023, 04:30 AM
          • harp
            high voltage high resistance marking resistor
            by harp
            Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
            08-26-2024, 01:42 PM
          • harp
            Low voltage very high current rails distribution
            by harp
            Low voltage very high current rail distribution
            I have some mains toroid transformer220v/12v, and thinking to add a few one-two turns fat coil in parallel, like in picture. Red are working windings, purple (top and bottom) is rails who connect all low voltage windings.
            Question is, how to connect that device to be as much more efficient in spot welder operation to distribute and pulls currents to all winding equaly, minimalize voltage drop?
            output on half E-F
            output on C-B
            connect A-B and C-D, output on A-F
            otherwise?...
            10-27-2023, 02:45 PM
