Power Supply 17IPS16-3
  • steffen55
    • Jul 2012
    please could you help me with some basic troubleshooting hints for a Vestel 17IPS16-3 power supply from an LCD TV.
    The power supply seems to have no output at all. I can measure a voltage of ~325V at the primary side of TR800 but no voltage at all at the secondary side. Looks like it's shorted.
    Are there any inputs to locate or at least to isolate the fault?
    Thanks!!
  • PowerAmpFreak
    • 982
    • Sweden
    Re: Power Supply 17IPS16-3
    It appears the SMPS recieve proper rectified mains. I assume TR800 is the main SMPS transformer, right?
    Either the SMPS has problems to start, like a dried start-up electrolyte (use to be 10-220uF cap close to the switch controller, like UC3842, 3843 and so on)
    Either the SMPS does start, but has one or more of the outputs shorted.
    In this case, the supply use to enter "hick-up" mode and a sound is heard from the supply.
    I don't know a thing about the relevant SMPS in this post, but this is just general advice to get a "dead" SMPS up.
    • steffen55
      • Jul 2012
      Thanks a lot for your response! Regarding your questions:
      - yes, TR800 is the main transformer
      - removed all the electrolyte capacitors right now and will remeasure them tomorrow
      - there is no sound from the SMPS
      Is there any possibility to measure the cirquits to isolate the problem?
      attached the schematics of the SMPS
        See if you get a good Vcc on IC805. Measure with your COM terminal connected to the negative end of any of the main input caps.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          03-31-2024, 02:12 PM
        • shamsudeen
          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
          by shamsudeen
          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
          i know that in linear power supply the noise will be very low comparing to SMPS supply....
          07-19-2025, 07:14 AM
          07-01-2024, 06:34 AM
        • JimBanville
          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
          by JimBanville
          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
          09-13-2023, 07:21 AM
