LG 42PC3D - UD Turns on and off till power is unplugged
  • shizzel
    • Jul 2012
    • 6
    • usa
    Hello all,
    I've been scouring the forum looking for a solution to my problem. Please forgive me if this question has already been answered. Here's the back story on the unit. The power on/off happened intermittently for about 6 months till the set popped and the picture went out. I traced it to a bad y-sus board. I purchased a new board and the tv worked fine for about a month.
    Turned tv on a pop. This time the z-sus board went. I had the z-sus board repaired by a reputable business mentioned n this site. About a month after the z-sus board was replaced, pop. Y-sus board went bad. I sent the ysus board in for repair. Just got it back last Wednesday and now the tv turns itself on and off until I unplug the power chord from the tv. Before I turn it back on and hear another pop does anyone have any ideas as to what could be causing the ysus to fail?
    I read that the power supply could be bad. I opened up the tv and there are no signs of bulged caps. Any help would be greatly appreciated.
    Re: LG 42PC3D - UD Turns on and off till power is unplugged
    This could be the common AC detect issue; which is fixable.
    The Y-sus and Z-sus should not fail so often. Your Vs voltage may be too high.
    • thelmores
      • Feb 2011
      • 17
      Lots of TV companies suggest replacing the y-sus and z-sus at the same time..... looks like you learned that lesson the hard way. Some even suggest changing the y-buffers when you change the y-sus.....
      Seems like something could be loading down your power supply, like a bad y-sus or z-sus...... or possible bad y-buffers.....
      I would disconnect the y-sus and z-sus one at a time, and see if the power supply stays on. You may even have some bad y-buffers........ If you disconnect the y-sus from the power supply, and the power supply stays on, You may even have some bad y-buffers....... you would have to disconnect the buffers from the y-sus to isolate the fault between the two if thats what it comes down to.....
      obviously, after the boards have been installed, and tv is running, you want to verify and tweak panel voltages, labeled on the sticker on the panel.
      • shizzel
        • Jul 2012
        • 6
        • usa
        Thanks for the quick replies. Unplugged ysus. Power stays on. Vs voltage 188.6 and 188.5. Both in and out of the power supply. I metered power coming out of the power supply to the ysus at 5.21 volts. Metered the power in to the ysus at 5.19 volts. Plugged ysus back in and popped the fuse....... UGH!!! heading to get some fuses. If that works I'll unplug the y buffer....
          These TVs are notorious for blowing their Y- and Z-sus due to the extreme amount of heat produced.
          • shizzel
            • Jul 2012
            • 6
            • usa
            Good news sort of, i replaced the fuse and plugged ysus back in. Picture works. Metered the ac det. Stand at 4.89 volts when the tv is on or off. while I had the meter hooked up the tv cycled off and the volts dropped down to .38 I had to manually turn the tv back on and the voltage went back up to 4.89.
            Tom66, I found an ac detect post of your in another thread. Could it be that the ac detect is sending a surge to the ysus when the power cycles n and off causing the ysus to fail? I noticed that the fix involves soldering pins 3 and 4 together optocouplers. Should the ac detect read anything when switching the tv on? I'm thinking of doing your bypass procedure.
              AC detect is unrelated to Y sus failures. Face it, LG designed these badly. The early revisions kill the Y sus and the replacement IPMs don't seem to last too well either.
              The bypass procedure comes only at the risk that the sound will click or pop when turned off. Also I've only tried it on the 42PC1D, so can't confirm compatibility with 42PC3D.
              • shizzel
                • Jul 2012
                • 6
                • usa
                Thanks Tom, was hoping for a magic bullet answer. My power supply board is the exact same as the board you posted in the other thread.
                • shizzel
                  • Jul 2012
                  • 6
                  • usa
                  Tom66, bypassed optos. No on and off... Looking good so far. Thanks for the suggestion. I want to put fans on the ysus and zsus. Should i pick up power from any particular place? Thanks again for the opto bypass!
                  • shizzel
                    • Jul 2012
                    • 6
                    • usa
                    Got it handled. scabbed 2 5v fans out of an old laptop fan. Connected power to the molex into the ysus and zsus. Tv has been on for 3hrs. Hasn't shut down once and heat sinks on the ysus and zsus are slightly warm to the touch. Thanks to everyone for their advice.
                    • electronicsurplus
                      • 210
                      Great work tom
                      Just used the same method (opto bypass) on the same television and so far still working. I never thought of that. excellent
                      Jon
                      This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
                      Help keep these from the landfills
                      • robk627
                        • Nov 2012
                        This may be a dumb question, but are the solder points for the opto bypass the same on the 42PC3D as they were on the 42PC1D?
                        I am having the same problem shizzle had.
                        Havent pulled open my 42PC3D since changing the 10 caps in the Power Supply.
                          Post a picture of the topside and underside of PSU and I will highlight them.
                          • tblock
                            • Aug 2014
                            Can someone please post a link to this 'opto bypass' thing? I picked up a 42PC3D for $10 because it had a problem and the guy just wanted to get rid of it.
                            Basically, I plug it in and it just keeps clicking on and off. The display briefly lights up and turns off with the sounds of the click.
                            Looking at the power supply, I can't see any bulging in any of the caps. I unplugged the z-sus board and tested the 5V pins with a multimeter, each one wouldn't give steady readings.. the numbers jumped around.
                            • Salvatore057
                              plasma TV Lg 42w451 - why is the zsus igbts damaged when the ysus is plugged?
                              by Salvatore057
                              I am trying to fix my plasma TV which is not powering on due to damaged IGBTs. I have changed two igbts and 2 IC drivers on the zsus and also two igbts on the ysus.
                              Now everytime I plugged the ZSUS and the YSUS boards to the power board, the two 30f124 IGBT on the ZSUS are damaged and the TV stays in standby mode. When I plug the ZSUS board alone the TV turns ON but I do not see pictures. When I plug the ZSUS board without the two 30f124 IGBTs and the YSUS board, the TV powers on with a picture.
                              I am lost, should I change the YSUS board? Is the YSUS board damaging...
                              04-29-2018, 01:29 PM
                            • JDC
                              LG 60PB6650 - Bad ZSUS (3.8v to YSUS instead of 16v)?
                              by JDC
                              Make and Model: LG 60PB6650-UA
                              Issue: Turns on, no backlight, can hear static (no channel)
                              I've been repairing TVs for a couple years now. I know how to use a multimeter for the most part and know how to test most components for shorts.
                              The power board connects to the ZSUS and then connects to the YSUS. The ZSUS is where I believe the failure is because the 16v line is only 3.8V, even when I disconnect the ZSUS from the YSUS.
                              This particular model seems to have a common failure with its YSUS. My goal earlier was to prove the YSUS was bad so I could...
                              09-13-2018, 02:12 PM
                            • legg
                              LG 42PC3 buffer output doesn't follow YSUS
                              by legg
                              LG42PC3D -UD originally with green lamp but no display or audio.
                              Owner says was working, then went 'pop'.
                              All 5V caps bulging. replaced.
                              All PSU output voltages within spec but -Vy is low on YSUS.
                              One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                              eventually shorts DG. Replaced all 3 - -Vy now OK.
                              Y scan buffer test point does not follow YSUS output below -50V
                              Note: This unit seems to expect YSUS output to park at -Vy in between
                              drive signal pattern periods. A replacement drive signal board confirms this....
                              11-18-2021, 11:49 AM
                            • Tycoon
                              LG 50PJ550 clicking/not staying on
                              by Tycoon
                              I recently received a LG Plasma TV (50PJ550-UD) which clicks upon pressing the power button however after another clicks turns off. There is no image displayed during this time. I attempted to troubleshoot and unplugged both the YSUS and ZSUS board (the ZSUS board plugs in to the YSUS on this model). With the ZSUS board unplugged the power stays on. With the YSUS connected the 2 clicks and then power down occurs. I replaced the YSUS board and buffers thinking this was the issue however the issue remained. I also thought it might be the power board which I replaced and still the same issue. I was...
                              06-23-2020, 03:18 PM
                            • flat-earther
                              ASUS X54H laptop thinks it's always charging even with charger unplugged
                              by flat-earther
                              The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                              Windows also shows ''Plugged in'' when charger is not connected.
                              This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                              Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                              If I let battery run out and say it has 3% Windows will...
                              06-24-2025, 09:32 AM
