Myrica p42-2H green shadows
    Re: Myrica p42-2H green shadows
    have checked it 25 times Power button is at the button of the TV and are not holding it
      Its weird. I Starts like normal, but when it should start up the screen, it shuts down.
        Does it behave differently if either sustain board is disconnected?
          have tried disconnecting both boards. One at a time and at the same time.
          TV clicks (switching on click), the power supply is buzzin. 1 click more.. 5 seconds, blinking front led.
            Tried testing Vs power to Y-sustian. It gets 208 like it should. Maybe the board failed?
              It could be. Maybe the fluctuating voltage has damaged it. Do you own an oscilloscope?
                no, I do not own one :S
                Now the Front LED is not blinking, but is steady.
                Did listen more to Power Supply. It is like the buzzing is
                changing to another pattern after 5-10 seconds.
                  Does the buzzing change if sustains are unplugged?
                    No, same buzzing sound
                    Or maybe. When they are connected,
                    it is more like a wave buzzing (up/down/up/down
                      When it is switched on, can you turn it off normally with the remote control?
                      Sound is still good?
                        Yes, can turn on/off. Change channel. Mute and so on
                        All with remote.
                        Sound is perfect
                          Very strange. I wish I knew what the problem was. I can only think of a cold joint or loose connector.
                            Will try to take out the power supply and look under the print. I worked before I pulled it out and tested the resistors.
                              It is weird. Still not working. Maybe Y-sustain or Y-buffer is just burned out. It is a very old TV and have read on the net that these Samsung Y-buffer burn out easy.
                              The Power supply was unstable with Y-sustain connected and know it is stable with it connected, so the Y-sustain is not pulling any power.
                              The Z-sustain is also getting warmer,
                              but Y-sustain is cold, so I think it does not get power
                              through it. (error on Y-sustain).
                                Does this TV use two buffers? If it does, try it without the top buffer. Then, try it without the bottom one.
                                  Will try that.
                                    Did not help. I think my Y-sustain is damaged/dead.
                                    It is a Samsung LJ92-01200A if that helps.
                                      Under the large metal heatsink on both sustains there is a "Hybrid" IPM module.
                                      Can you remove the board and take a picture of the underside of this module? (the pins.)
                                        Of course, give me 5-10 minutes
