Re: 50" Samsung Plasma (model number PS50Q91HD) - possible purchase
OK ysus is back together.
Sound with no picture with no buffer board installed (no surprise).
Installed the lower buffer board only - still no picture which was a bit of a surprise although tw2005 mentioned the same thing with his similar model Samsung.
Not brave enough right now to reinstall the upper buffer... I have removed the melted upper buffer chip, and the shorts to the three bottom pins are now gone...
checking the pins tom66 suggested earlier - the top 12 pins all 'short to each other' I assume these are the earths.With the way tom highlighted the top half and bottom half separately, I assume this is normal.
Similarly, the bottom three pins are all shorted to each other - I assume these are the power - although the Coppell post suggests 'On the TOP buffer board, the power lines are the top two lins of the black connector and ground are the most of the remaining connetors' This seems the opposite to what I'm seeing?
Resistances between the bottom two pins and the remaining pins are all opencircuit or megaohms - so I think I'm ok now with the one buffer chip removed. I just need some reassurance :/
