Lg du-42px12x half screen with colored lines/internal leds
  • drpj23
    • May 2012
    • 528
    Ok, so first off, this tv had the left (from viewing angle) side filled with colorful lines and the right had a big bar or two but was mainly black. If you lift up on the tv a little the lines disappear but you have like colorful static. And if you leave the tv on about 5 mins it shuts itself off.
    So was told that this would be a controller board issue and it fixed the lines on the right side...yay? (included picture)
    So bad controller board, or hoard of other problems? Oh, the Z sus board also is making a low whur sound right near the IPM.
    Voltages are good from the P/S.
    The main A/V board and controller board both have these internal LEDs. Could someone name there function, especially on the A/V board since some are red. I believe they can be both red or green considering there are 3 terminals per LED.
    Thanks.
  • rfxcasey
    Vertical Lines on Half of LCD Display
    by rfxcasey
    I have an Siemens HMI with vertical lines on half of the screen. These lines aren't scrambled garbage but rather very regular in pattern and color. I have replaced the LCD with a new one and still the problem persists. I'm wondering if this isn't indicative of a bad video process chip or video memory? Any help would be appreciated. The cable appears to be OK but one pin on the header is unpopulated, though there isn't any loose wire to suggest one broke off or popped out of the connector. In the picture below where the connector is busted out of the side, I did that with my small screw driver...
    05-16-2024, 06:52 AM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • kca
    by kca
    Hello all ~
    08-31-2025, 06:38 AM
  • rapid911
    Vizio M58Q7 colored horizontal lines
    by rapid911
    Hi guys, I have a Vizio M58Q7-J01 and now there are some colored horizontal lines on the screen. Could someone tell me if it's probably a panel issue or something related to other parts and can be fixed? Thank you in advance....
    05-28-2023, 04:17 PM
  • Gjackson
    LCD Tv starts to display black horizontal lines after half an hour of use
    by Gjackson
    Hi, I have a sort of old Grundig LCD Led TV that starts to display black horizontal lines after some use. After it's been turned off for a while and cold it does not display any artifacts however after some use it starts to display some faint horizontal lines at the top of the screen and a bunch in the middle of the screen. The longer the tv is on the worse they get until they become very clearly visible. I suspect that heat has something to do with this as when the lines start to appear i notice that the tv's metal case has gotten warm. Could the T-CON start to malfunction when it starts to get...
    01-31-2022, 02:25 PM
