Problem with a Toshiba Model #42h81 Rear Projection TV
  • anton02
    • Apr 2012
    • 14
    • United states
    I have one of these TVs that i found in the garbage i hook it up to my PS3 and in 1080p mode i get a picture but when i try to play a game or go in to any other in put (AV, CABLE) the screen goes al scraggly and no picture.
    I've read on another forum that i can re cap the master board but no one could tell me which board was the master board or supply pictures.
    does any one have any info on what the problem is, or any pics of the master board?
    im kind of a novie at working on electronics but i have fixed quite a few computers and gamings systems, and i also have experience soldering.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Problem with a Toshiba Model #42h81 Rear Projection TV
    Welcome to the forum-
    If you read some of the threads you will see that is not really the way the forum works.- You will need to open up YOUR tv and post pictures of the boards. You will need to look/check for problems - dust - glue blobs.
    Burns/signs of overheating burst/bulged caps, cold solder joints loose connectors. (easiest place to start)
    Post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Examples of what is needed
    https://www.badcaps.net/forum/attach...1&d=1290283049
    https://www.badcaps.net/forum/attach...7&d=1280167246
    Do you have a multimeter and can you use it?
    Have you tried the TV with DVD input - Cable/aeriel input. Is the sound ok
    When the pic goes black is the sound still on and what does the power led
    do. When it is in fault and you switch it off /unplug what does it do when you turn it back on.
    • anton02
      • Apr 2012
      • 14
      • United states
      thanks for the guidance when the picture goes all scraggly the souond is still there and the tv works as it should all except for the picture.
      and yes i have a multimeter and i will post pics in a bit
      • anton02
        • Apr 2012
        • 14
        • United states
        ok here are the pictures o got the power board, there are two boards that are soldered to the main board i don't want to remove them unless i have to.
        the last 5 pics are the main board.
        • jeffescortlx
          • May 2011
          • 40
          A lot of the older RPTV can only support 1080i.
          So before you start ripping stuff apart, go into the monitor settings on the PS3 and force it to 1080i and try that.
          • anton02
            • Apr 2012
            • 14
            • United states
            ok i am having a problem uploading the pics. ill have to post them later.
            also yes i made sure the ps3 was in 1080i mode.
            also there were two main boards in the television one for video components, and the other for power supply i cant take the power board out all the way because of some huge wires that go to the projectors ill try to get pics of it also and post them later
            ... in the mean time does anyone know which board is the master board?
            • anton02
              • Apr 2012
              • 14
              • United states
              im sorry i was mistaken it is the hyper board
              • anton02
                • Apr 2012
                • 14
                • United states
                I found the hyper board sorry for lack of pics.
                I will try to upload pics of what the problem was in case anyone else is in the same boat I am.
                • anton02
                  • Apr 2012
                  • 14
                  • United states
                  that.
                  • delphi_firebird
                    Toshiba Qosmio X755 Charging problem
                    by delphi_firebird
                    Hello Guys,
                    I received Toshiba Qosmio X755 that has a charging problem and I'm stuck trying to figure out the problem.
                    - When battery is unplugged i works without any problem.
                    - When I plug in the battery after plugging in the charger, it works correctly and the battery is charging.
                    - When I plug in the charger after inserting the battery, it stops working. ( voltage dropped and consumed 8A, reaching the maximum capacity of my bench power supply for 5 seconds, and stop working after )
                    Can you help me diagnose the problem? I have attached...
                    10-16-2023, 03:04 AM
                    Toshiba Satellite L50D-B-11V Notebook Specification for Upgrade or Repair
                    This specification for the Toshiba Satellite L50D-B-11V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L50D-B-11V boardview and L50D-B-11V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                    09-06-2024, 05:27 AM
                    Toshiba Tecra C50-EC Notebook Specification for Upgrade or Repair
                    This specification for the Toshiba Tecra C50-EC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C50-EC boardview and C50-EC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Tecra...
                    09-06-2024, 09:01 AM
                  • hadyshahat
                    Problem toshiba dynabook R734/m from BIOS
                    by hadyshahat
                    Hello my friends
                    Please help me
                    I have a Toshiba laptop with a password on the BIOS and the programmer does not read the chip
                    Unable to read the IC
                    These are the device data​...
                    10-26-2024, 07:40 AM
