DVP642 turn off after 2 minutes
  • rmg_hrr
    • Mar 2012
    • 27
    • India
    My DVP642 Philips DVD player refuses to play and goes in to Standby mode,
    When searched I found this could be due to bad capacitor 316.
    Which i now replace with another low ESR cap 1000uf 16V.
    Still the problem not solved.
    Also I observed that the Vibrato Chip is getting heated quickly and.
    This was happening even before I replace the capacitor.
    Can you help?
    DVD player is about 6 years old.
    regards & Thanks
  • Rolin
    Onkyo/Integra DBS-50.2 Blu-Ray Player - Won't turn on or shuts off immediately.
    by Rolin
    I have an Integra DBS-50.2 Blu-Ray Player that I haven't used in a while. Tried to turn on and it turned on for a brief moment with "hello" on the display then shuts off. Dead from that point on unless I unplug it and try again. Took it apart and checked a few well labeled voltages on the Power Supply board and found the 3.3V isn't measuring on the board (unless I'm misunderstanding what I'm measuring). I have a few pics of the board and schematics. There's a 4 PIN voltage regulator at location IC1301 with a part number 070XFC1 by Sharp that I believe should output 3.3V on PIN2,...
    09-07-2024, 12:11 AM
  • ndarjo21
    Turn on 1 minutes and then turn off. Lenovo ideapad 110-14ast
    by ndarjo21
    Hello all, i have problem with this laptop. When i press the power button it will turn on and get picture in the display. But the fan havent turn on. Few second later, the fan star spinning. After 1 minutes, the display and the fan turn off immediatly, the motherboard also turn off. When i check in power inductor near the cpu, it warm. 2 of them. When i check another power inductor nearby ram, thats all cold. Can someone help me or even solve this problem?
    12-27-2021, 06:25 AM
  • r ez a
    svf15 (GD6) turn off after 2 about minutes
    by r ez a
    hello my friends
    i have 3 motherboard with same problem, i thest them on two laptop
    it doesn't matter where you are, it turn off in less than two minutes
    ist not temperature problem
    i tried bios but doesn't help any idea?
    11-01-2023, 02:32 AM
  • valvashon
    Samsung LS23PTNSF/ZA- Erratic behavior 20 minutes after turn on
    by valvashon
    This smaller Samsung TV will turn on fine and work fine at first. By this I mean that it will respond properly to the remote commands with channel up and down working and volume up and down working, etc.
    After the set has been on for a while- 20 to 30 minutes- it stops responding or responds erratically to commands from the remote or the front panel buttons. Remote is fine, works well with other TV's.
    My guess is caps in the power supply warming up and changing value leading to the erratic behavior. TV does not act erratically unless you try to change a channel or something like...
    06-16-2023, 01:22 PM
    MEDION AKOYA S15447 + ext. DVD Player Notebook Specification for Upgrade or Repair
    This specification for the MEDION AKOYA S15447 + ext. DVD Player Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S15447 + ext. DVD Player boardview and S15447 + ext. DVD Player schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
    09-06-2024, 05:30 PM
