svf15 (GD6) turn off after 2 about minutes
  • r ez a
    • Sep 2014
    • 39
    • iran
    hello my friends
    i have 3 motherboard with same problem, i thest them on two laptop
    it doesn't matter where you are, it turn off in less than two minutes
    ist not temperature problem
    i tried bios but doesn't help any idea?
  • ndarjo21
    Turn on 1 minutes and then turn off. Lenovo ideapad 110-14ast
    by ndarjo21
    Hello all, i have problem with this laptop. When i press the power button it will turn on and get picture in the display. But the fan havent turn on. Few second later, the fan star spinning. After 1 minutes, the display and the fan turn off immediatly, the motherboard also turn off. When i check in power inductor near the cpu, it warm. 2 of them. When i check another power inductor nearby ram, thats all cold. Can someone help me or even solve this problem?
    12-27-2021, 06:25 AM
  • valvashon
    Samsung LS23PTNSF/ZA- Erratic behavior 20 minutes after turn on
    by valvashon
    This smaller Samsung TV will turn on fine and work fine at first. By this I mean that it will respond properly to the remote commands with channel up and down working and volume up and down working, etc.
    After the set has been on for a while- 20 to 30 minutes- it stops responding or responds erratically to commands from the remote or the front panel buttons. Remote is fine, works well with other TV's.
    My guess is caps in the power supply warming up and changing value leading to the erratic behavior. TV does not act erratically unless you try to change a channel or something like...
    06-16-2023, 01:22 PM
  • RdeveLabs
    MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
    by RdeveLabs
    To all the members here...
    Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
    So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
    05-05-2025, 04:59 AM
  • masoksian
    Dell latitude e7470 not turn on .power buton on off and Run Power problem
    by masoksian
    I am dealing with the problem of turning on and off my Dell e7470 notebook.
    The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
    The system does not turn on, there is no post.
    I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
    The problem continues in the same way.
    I tried to turn on the Fn key, nothing came to the screen....
    02-15-2025, 12:08 PM
  • Ledgurra
    MacBook Pro A1425 it doesn't turn on
    by Ledgurra
    hello! hope you are all well. i have a macbook pro a1425 and it won't turn on. i took it to the service center and they said it's fine, it turned on 2 times and then it wouldn't turn on. on the power supply there is a yellow dot that is charging and turns green when charging but when i turn it on it doesn't turn on. i opened it and saw on the motherboard that 2 elements are missing, i am attaching the photos for you to understand better.
    thank you all
    11-09-2025, 06:07 AM
