Need a little help with a Plasma 42MF230A/37
  • jeffescortlx
    • May 2011
    • 40
    This is a magnavox 42" Plasma from 2006.
    It had a Buffer chip short on the PBA: LJ92-01203A board.
    It's my understanding that the TV should still power up and try to to display (as much as it can with the missing buffer) once the bad buffer is removed.
    The TV still will not power up, and the power supply makes some noise like it's being over worked. So I think the shorted buffer damaged the Y-main LJ4-02759A LJ92-01200A.
    The Y-main did have a bad R5028, R5090 & D5009, that I replaced but did'nt make a difference.
    But I'm thinking maybe the large STK chip under the heat sink is shorted also.
    No bad fuses or caps.
    Any one have any exsperiance with these?
    Thanks for any help!
    Re: Need a little help with a Plasma 42MF230A/37
    Does the PSU make noises when either Y or Z sustains are disconnected?
    • jeffescortlx
      • May 2011
      • 40
      There is a short some where on the Y-main. The large draw goes away when the Y-main is disconnected. But the TV wont power on either.
      Have you rebuilt the Y-main before? Is it just the large STK chip under the heat sink?
        Never done it myself thankfully, as it's quite difficult. Usually just the large STK power hybrid shorts on one of the rails... or sometimes all of them. Some people also do repairs on these boards on eBay.
        • Yanleb
          Schematic or datasheet for Plasma TV buffer chip
          by Yanleb
          I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
          So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
          Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
          05-18-2022, 01:36 PM
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • Bad_Boards
          LG Plasma TV Bad Y Buffer Replacement
          by Bad_Boards
          Background:
          I have a LG 50PA550 Plasma TV which stopped displaying a picture. The sound works just fine. The outputs of the power supply board were within 2% of the expected values. After removing the Y top buffer the bottom half of the TV started working.
          Question:
          Do I have to order both a Y-Buffer and Y-Sustain board to fix this?
          Could I somehow check the Y-Sustain board to see if there was any damage done to it?
          04-07-2021, 09:39 PM
        • jm1234
          Panasonic plasma TX-P42ST50 - 6 blinks
          by jm1234
          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
          I checked that board for any obvious faults...
          05-22-2024, 06:59 AM
