LG Plasma TV Bad Y Buffer Replacement
  • Bad_Boards
    • Apr 2021
    • US
    Background:
    I have a LG 50PA550 Plasma TV which stopped displaying a picture. The sound works just fine. The outputs of the power supply board were within 2% of the expected values. After removing the Y top buffer the bottom half of the TV started working.
    Question:
    Do I have to order both a Y-Buffer and Y-Sustain board to fix this?
    Could I somehow check the Y-Sustain board to see if there was any damage done to it?
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    Re: LG Plasma TV Bad Y Buffer Replacement
    If the bottom half of the panel is displaying correctly, for example: not dim, not grainy or other common Z/Y boards partial failure, it should be fine, some LG plasmas require upper buffer boards to display any picture on the bottom half.
    • ajshoe
      ajshoe
      • Dec 2012
      • 477
      • usa
      you need a new top buffer board.
      • Yanleb
        Schematic or datasheet for Plasma TV buffer chip
        by Yanleb
        I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
        So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
        Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
        05-18-2022, 01:36 PM
      • KYBOSH
        Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
        by KYBOSH
        Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
        No picture but you hear the TV static (white noise) playing loud and clear.
        The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
        But it seems they didn't get too far and just left it.
        When I first took a look I was amazed at how pristine the inside looked.
        Its as if the TV had been in a time capsule.
        Caps looked like they were just pulled off the self.
        Copper coils had no sign of corrosion on...
        02-01-2023, 11:10 PM
      • dajoker
        Panasonic th-p50s10d - blinky red, SC board go boom
        by dajoker
        My old plasma died when one night recently. When I got to it it was giving a 3.3v sos (3 blinks).
        I chased my way through the PSU, and a board, with no results.
        Replacing a few bulged caps in the PSU, I eventually got to the SC board that had piles of shorts, a quick cheap replacement from china and the tv powers up again, except
        I only have the right half of the picture.
        Left half is completely blank.
        now the c3 board running this side of the screen has its 3.3 and 5v onto the buffer ic and its got the 60v, so that all seems good.
        all the other voltage rails...
        09-24-2024, 04:39 AM
      • howardc64
        by howardc64
        Yesterday, 05:17 PM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
