Samsung Spn4235 No video or sound
  • lilmonk3
    • Apr 2012
    • 259
    Re: Samsung Spn4235 No video or sound
    hopefully those caps maybe your issue then hope you have better luck with the new set you have picked up for free.
    Lets hope.. Just the short time I have been here, I have learned a lot about working on things... And thats because of all the great members here..
    • TechShui
      • Jun 2011
      • 148
      Originally posted by lilmonk3
      Techsui.. I was having the crazy readings myself. But its because the TV would shut off while I was testing..
      Yeah, my TV shuts off at random too.
      This TV is crazy I keep hoping I might turn it on and everything will be working. After all, it was working fine before, even with those bulging caps.... sigh.
      The last time it shut off was last night when I was probing pin 15 (GND) of the PFC chip. I heard the usual buzzing or 'chirping', before the TV went off. This makes me wonder if touching that pin causes it to go into protection mode? But all the other times I heard buzzing noises, none of them resulted in the TV shutting off, so maybe this was a coincedence. I can't see any pattern in this TV's behavior.
      No buzzing sounds here though
      Do you mean you already probed the PFC (the 16-pin chip at location IC1) and there was no noise?
      What were your voltages? Especially pin 13 (Vcc) of the chip, is it steady?
      If you haven't tested it yet, be sure to use pin 15 of the same chip for ground. Although it can be awkward to measure small pins so close together with these probes.
      I recommend using rubber gloves too. Since the chip is in the area between the big heatsinks.
      • TechShui
        • Jun 2011
        • 148
        Can anyone please help me find the service manual? ElektroTanya comes up empty.
        This TV is still an enigma. I think it's showing me error codes.
        I got a spark from one of the inductors, this was definitely my fault, as I was shifting the board with the TV plugged in.
        In my defense, I thought it was unplugged And
        I had been working on it all day and was very tired at that point.
        The main fuse blew after the spark, I replaced it. And now this:
        Solid red LED for 4 secs, then blinks 2 times (at an interval of 1/sec)
        Then blinks faster (3 times/sec) red, orange, red, green, red, orange, red, green
        Then blinks green continuously like it was doing a week ago, and just like then, I have to unplug to turn off.
        OK, scribd search for "SPN4235", gives several results for PS42P3sx chassis service manual, could that be it?
        http://scribd.com/search?category=&l...amsung+spn4235
        My chassis does not match though, so I'm dubious. Here's my info:
        Model: SPN4235
        Type: AX42P3
        Chassis: ALDC8 [ADFC12]
        EDIT: After skimming the whole thing (only 39p, pretty small for a plasma with such a complex design) I believe it actually is the manual for SPN4235. Pages 36 - 37 are identical to PS schematic I have. So unless there's another model with the same PS board, this is the manual.
        Very disappointing, A search for "error codes" brings up nothing. Skimmed the whole thing and it's devoid of any useful info, no troubleshooting steps, no LED codes. It doesn't even have diagrams of the other parts! (sustain boards, buffers, G and F drive, etc not there).
        Is it possible this is a partial manual? or has samsung always been this skimpy in their service manuals?
        Last edited by TechShui; 05-08-2012, 12:47 PM. Reason: Looks as though it is the manual
        • DavidOH
          • May 2012
          • 105
          This one has your model listed.
          http://www.scribd.com/doc/87090514/Samsung-Pdp4298ed-ET
          • TechShui
            • Jun 2011
            • 148
            Sorry to revive a dead thread, but I'm curious to know if lilmonk ever fixed her SPN4235? She said she was waiting on some capacitors she ordered... and I wonder how that turned out.
            Hopefully she's subscribed to this.
            I would also like to add, that I found a scorch mark near IC30 which is to the left of the upper green transformer in this pic: https://www.badcaps.net/forum/attach...2&d=1335460697
            EDIT: The scorch mark was on the trace leading to the vcc pin, not on the chip itself, actually, it's closer to a 2.4k ohm resistor which also looks burnt.
            • mine_us_3
              • Jun 2012
              I am curious as well, as I have the same TV doing the same thing. Caps all look to be good but the BIG caps look to have gotten taller. They aren't bulging but it looks like the outer sleeve has been recessing on the top of the cap and one poly cap is about to come off.
              • TechShui
                • Jun 2011
                • 148
                Mine_us,
                Have you had a chance to check the voltages?
                And check the trace leading up to IC30, you'll have to flip the board over to the solder-side to see the trace. On mine there's a scorch, near R34.
                The color bands indicate a 2.4k Ohm resistor, but they don't carry that at RadioShack, so I replaced it with a 2.2k and 220 Ohm in series... no change.
                There must be something else shorted, the logical step would be for me to replace IC30 next. I think think that's a 12V supply IC, it's hard to read the schematic, it's very blurry, almost as if someone scanned it at a low resolution from the paper version.
                Schematic attached, I'm open to suggestions, if anything else looks like it's worth replacing I might as well order it at the same time as the IC.
                I'll be getting it from DigiKey.
                • gl4709
                  Samsung un55cu7000d with backlight and sound No Video / Picture
                  by gl4709
                  I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
                  01-23-2025, 06:21 PM
                • Max514
                  Samsung UN55H8000 sound but no backlight no video
                  by Max514
                  Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
                  The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
                  I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
                  • Unplugging the main board cable at the power supply >>> backlights came on.
                  • BLU_ON signal from the
                  04-14-2022, 10:34 AM
                  09-07-2024, 05:50 AM
                • alro7779
                  Samsung UN55MU6103F video problem; has colored stripes on the display
                  by alro7779
                  Hello, everyone!
                  A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                  09-27-2025, 11:29 PM
                • soeren
                  A2442 - No sound over internal speakers and no video playback
                  by soeren
                  I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
                  All happened after the battery ran out of power overall several days when I was on vacation.
                  I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
                  07-26-2024, 01:24 AM
