Out of the blue my Vizio went from color to black and white only picture. Has anyone encountered this problem or does anyone have some idea what could be causing it?
Vizio E320VT Black & White Picture Only
Have you ever stopped to think and then forget to start thinking again?
As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."Tags: None -
Re: Vizio E320VT Black & White Picture Only
On all inputs, including HDMI?
Checked the Colour/Saturation option in the menu?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
I would sugest finding the reset factory defaults option in the menu. Tell us if that works. And also see if theres color on the menu / or and of the other inputs (hdmi, component).Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.Comment
I will try the reset and also the menu option. I only have one source for imputs. I will try to hook it up to my computer HDMI connection. Thanks for the suggestions.Have you ever stopped to think and then forget to start thinking again?
As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."Comment
by yankysHI everyone Pick up this 55" VIZIO tv that only plays in black and white picture doesn't matter what inputs HDMI or apps, but all the menus are in color, if you're on Netflix everything in color until you play any show. I'm thinking main board if so, can the board be reflowed to try and correct this?
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by sgcampionHello,
Asus rog strix scar 17 G733QR
My Asus laptop started flickering from time to time and more and more in last months. First the screen was going black but sometimes if I moved the screen it would work again, other times I needed to plug/unplug the laptop or close and open the lid to make it work again.
In last days I see that if I move the laptop lid to about 45 degrees it will flicker or get white or black screen(it's random, sometimes white sometimes flickers etc). I was trying to troubleshoot it myself but seems like it's either the cable or the display....10-24-2023, 09:39 AM -
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
by hcinneHello,
I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the... - Loading...
