Hi all, this place seems to be an amazingly knowledgeable and helpful community, I'm really hoping you can give me some guidance with this issue.
First of all, my setup. I'm running a HTPC with XBMC from an old laptop, connected via a DVI to HDMI cable. Since I only use the TV for the HTPC, the audio runs straight from the laptop to an external 2.0 system I have. As home theatres go, hardware-wise this is extremely simple.
As for me, I have experience with setting up HTPCs with TVs and am generally very technically inclined when it comes to computers and software, but my hardware knowledge of TVs is pretty much non-existent.
I bought this Samsung PS50C91HD plasma screen today second-hand, the seller told me about the audio issue before I bought it but I got a very good price for it, so I figured it'd be worth having and perhaps circumventing the audio problem.
First of all, the video is perfect. Looks fantastic running at native resolution (1360x768) via HDMI. Massive improvement in image quality from my previous TV. No issues there, I'm very happy with it in this regard.
However, it seems there's a problem with the audio board in the TV, as it clicks every second or so. It sounds like the same kind of click a TV makes when it turns on, but it seems that it fails to load properly, and so keeps trying. I'm guessing it's a faulty audio board, if there is such a thing. The click seems to be coming from near the bottom right corner of the TV.
At first I thought muting the internal speakers - since I am not using them at all - would work, via the TV's setup menu. The click persists. I've searched around the menus to try and find another option that would disable the onboard audio, but there is nothing else except an "Internal Mute" setting, which does not stop the clicking.
I've tried running the audio through the TV (3.5" jack from laptop's LINE OUT to HDMI/DVI IN, then AUDIO OUT to subwoofer). The audio works (through the external speakers, not the TV speakers), but cuts out with every click.
Even if not muted, the TV's speakers do not work. I don't particularly mind since internal speakers are pretty bad anyway and I'm fine with the audio running straight from the PC.
However, I can't get rid of the clicking noise. No matter what channel the TV is on or what source it's using, even if it's a blank screen with no audio, the clicking persists. Seems like the TV is desperately trying to initialise audio from the moment it's turned on, but is not able to do so because of a hardware fault.
I found out how to access the service menu and had a cursory glance around for any option that sounded related to the issue, but I am certainly not going to mess around with anything there without professional advice.
This is a relatively minor issue as when I'm watching a movie the volume from the speakers is usually loud enough to drown out the clicking. However, obviously this is not ideal, and I'd like to get rid of the clicking if it's at all possible.
So, in your undoubtedly more expert opinions, what are my options here to fix the clicking? There's no warranty. I've done some research and found that they don't make this model any more, and the vast majority of issues I've found from searching about the problem have been video related rather than audio related.
My best bet is probably to find a TV repair guy/engineer around here to come and take a look at it, and hopefully replace the faulty part (and even if that costs a fair amount, I'll still feel all right about it since I got the TV cheaply). However, since I don't even need the audio on the TV since it's running straight from the laptop and I'm only using the HTPC, I was wondering if there was some easier way to disable the audio completely so it doesn't even try to initialise (which I'm assuming is the source of the clicking). A couple of hours of looking online has failed to find a solution, so I'm hoping that somebody here may be able to help.
I would hugely appreciate any help or advice here. If you need any more information I'll be happy to provide it.
