I have this 50 inch LG 50pc1dr that is busted. It has the famed clicking with red/blue led light and then shuts off. There were some bad caps and I do not have a steady enough hand to change them all. I ordered a new board online and installed it today. This did not solve the problem. I've isolated every board and I can't get it to stay on.
I read about the AC Detect issue. There is the one plug connector that has ACD on it. If I remove this one only, the TV goes into a cycle, where it clicks and shuts off and then does it over and over.
So anyway, now I have two boards. I would like to short the AC Detect as Tom66 has advised on other threads, if you think this is a potential solution. I don't have any meters or tools, just a soldering iron. I'm willing to try this out on one of my boards without knowing if its the problem. I can't find a thread where the photos were the exact same power supply, so I need some help figuring out where I need to work.
Since the "new" board is installed, I photographed the old board for sake of convenience. I think I know where the target area is and took some close ups, but I would appreciate confirmation. It would be even better if you could put a line where the solder needs to go. Thanks so much!
These photos are quite large. I can make them smaller if necessary
http://dl.dropbox.com/u/12835111/lgtv1.JPG
http://dl.dropbox.com/u/12835111/lgtv2.JPG
http://dl.dropbox.com/u/12835111/lgtv3.JPG
http://dl.dropbox.com/u/12835111/lgtv4.JPG
