Polaroid FLM-3234B - nothing comes on. Standby Power is Present.
  • Vizor
    • Nov 2011
    • 215
    Re: Polaroid FLM-3234B - nothing comes on. Standby Power is Present.
    Don't have any laying around.
      How near is the nearest RadioShack in your town...
      • Vizor
        • Nov 2011
        • 215
        ill see about grabbing some later on today.
        • Vizor
          • Nov 2011
          • 215
          Question: when i do get the resistor do i solder it to those pins or just put it with where the wiring goes?
            Just try and squeeze it in where the wires are, otherwise you'll be soldering and resoldering it several times which can be a pain.
            • Vizor
              • Nov 2011
              • 215
              So, adding that resistor does nothing.
              • Vizor
                • Nov 2011
                • 215
                Got around to looking at the power supply again and i found this and i can't find a schematic of the Board.
                TC18607A Power Supply Board
                  Oh dear. Yes, that component looks like it has had a bad day. Z6 would suggest a zener diode. Approximately where is the component on the board?
                  • Vizor
                    • Nov 2011
                    • 215
                    Better Pics
                      What resistance do the resistors 102 measure? They may be bad too. I think they should measure 1000 ohms.
                      • Vizor
                        • Nov 2011
                        • 215
                        0.98 on 102 and 9.99 on 103
                          Okay, those look fine. Close enough for 5%.
                          That big thick trace coming from the zener area looks like the ground for the primary side.
                          This zener may only be the start. Something else could have been damaged. Was the TV killed by a surge, lightning, etc?
                          If I were to guess, it looks like it is part of a MOSFET gate circuit, so maybe 12 - 18V... but I wouldn't be certain. That is the problem without a schematic to go by.
                          • Vizor
                            • Nov 2011
                            • 215
                            looks like when it burnt out one side of the green layer came up. so the board is more less screwed id imagine.
                              No that is fixable, you just need to run a little bare wire to the pad of the nearest component. But it has been really badly damaged, something bad must have happened.
                              • Vizor
                                • Nov 2011
                                • 215
                                WTB schematic heh
                                • akuning
                                  ElctroEnthsiast
                                  • Mar 2014
                                  hello,
                                  i just activated an account here. akuning here from panorma city california.
                                  • akuning
                                    ElctroEnthsiast
                                    • Mar 2014
                                    i just have a question about the same power supply being discussed on this thread.
                                    i have a polaroid TC18607A power supply from polaroid TV FLM-3232. it started having the video come in and out. then no more video. i suspected the power supply so i started removing loads. i removed the 2 tuner boards and leaving just the main board powered by the power supply since i don't use the tuner coz i use directv box on the hdmi input.
                                    it worked for hours until i turned it off for the night. morning comes and i was excited to see the TV working again but to my disappointment, it turns the back-light ON and no more video even the POLAROID logo. it has audio but no more video.
                                    i opened it again and checked the power supply voltages. my readings:...the 5V gives 4.6v - the 12v gives 11.3v -the 24v gives 23.6v. this is with and without anything plugged onto the connectors CON5 and CON4.
                                    i dont see any bulging caps and everything looks normal except for my voltage readings. i used a 2nd meter and it always was giving less than the voltage it supposed to give on the pins.
                                    any inputs i appreciate. thank you.
                                    • SkishyIshy
                                      Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                      by SkishyIshy
                                      Hey All,
                                      I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                      I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                      I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                      03-17-2021, 11:44 AM
                                    • tvguy12012012120
                                      by tvguy12012012120
                                      02-07-2025, 05:13 PM
                                    • rex98
                                      JS47A/JS57A/JS77A NM-E531 onboard ram disable
                                      by rex98
                                      hi i have this laptop IdeaPad 3 15ABA7 this is the boardview https://www.badcaps.net/forum/troubl...90#post3740490
                                      nm-e531 i tried all kinds of bios editing and it doesn't work. it doesn't have schematic but it has boardview with board ID details in it.
                                      maybe you could help me how to shift these resistors to disable its onboard ram.
                                      this is is the presents and not presents...
                                      Today, 03:39 AM
                                    • fharris1977
                                      Vizio D50u-D1 Dead Set No Standby
                                      by fharris1977
                                      Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                      12-28-2023, 10:25 AM
                                    • Crystaleyes
                                      Samsung BN44-00259A standby question
                                      by Crystaleyes
                                      Hi all.
                                      I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                      SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                      Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                      The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                      08-11-2023, 05:15 AM
